Old 10-07-2009, 11:54 PM   #1 (permalink)
goofyboy65's Avatar
Send a message via AIM to goofyboy65 Send a message via Yahoo to goofyboy65 Send a message via Skype™ to goofyboy65
Transmission Fuild Capacity
I know the capacity of the manual trans is 2.75 qts, what would happen if i decided to put 3 or 4 qts in? Would the gears slip?
2007 Sly Solstice Manual
--GXP Dual Exhaust
--GXP Rear Fascia
--4500K HID Headlights
--4300K HID Fog Lights
--K&N Air Filter
--Removed Resonator
--Blinker/Sidemaker Conversion
--Red Footwell Lights
--Red Bottom Door Lights
Is A Funkateer....Ya Dig?!?!?!
"One Nation Under the Groove
Getting Down Just for the Funk of it
One Nation and We're on the Move Nothin' Can Stop us now......I Promise to Funk, the Whole Funk and Nothin' but the Funk!"
goofyboy65 is offline   Reply With Quote
Old 10-08-2009, 05:37 AM   #2 (permalink)
ASETech67's Avatar
Send a message via Yahoo to ASETech67
Hi Goofyboy65
As with most components that have a maximum fluid capacity, substantially overfilling can cause seals to fail culminating in potential failure of the part due to lack of lubrication/cooling by said fluid. Fluid expands as it gets hot, which means there has to be space in the component for that fluid expansion to take place...if you over fill, you have less space for said fluid expansion, which puts undue stress on the seals, causing seal failure over time.
ASETech67 is offline   Reply With Quote
Old 10-08-2009, 08:38 AM   #3 (permalink)
Small Dealer's Avatar
Also, as Randy@ddmworks posted in your other thread on trouble with transmission fluid change, the filler location is on the side of the transmission.
It would be very hard to overfill the transmission by the up to almost 50% you are asking about.
INFORMATION POSTED ON SITE
