Old 02-23-2007, 12:58 PM
   TURBO GARRETT T3/T4 Hybrid A/R .60 TRIM 55
Jorgiuxxx's Avatar
Send a message via MSN to Jorgiuxxx
Hi eveyone Im a little new in this forum but im glad to be part of this. i just want to tell you that im installing a TURBO GARRETT T3/T4 Hybrid A/R .60 TRIM 55 in my sols. I almost have all the turbo parts that i'll need. ( Manifold, CAI, blow off, FMU, Waste gate, oil lines, gaskets, intercooler, etc) Im own of a 2.4L 2006, my question is, how much PSI of boost does my engine will support ? Somebody told me that the turbo that i got, is too mucho Big for my car, and may be it will run over the 4,000 RPM at least. Do you think that i have to upgrade the pistons or take down the compression ? What do you recommend me ? THanks you!
Jorgiuxxx is offline
Old 02-23-2007, 04:18 PM
The engine has been tested by others to about 13psi with the stock internals.
LatinVenom is online now
Old 02-23-2007, 04:27 PM
shabby's Avatar
55 trim? Never heard of that one, what size is the inducer/exducer?
shabby is offline
Old 02-23-2007, 08:54 PM
compression's Avatar
You wont need to run too much PSI. Just by a decent turbo and tune the car right. I made 311.8whp on a gt2876R turbo from garret. The housing a bit different from all the other turbos. But it got the job done on my car.
Performance Auto and Sound
Compression Performance
compression is offline
Old 02-24-2007, 07:53 PM
Jorgiuxxx's Avatar
At how many PSI are you running? Is my Turbo bigger than yours ?
Old 02-24-2007, 08:25 PM
right now I am running GT2876R Garret on 8psi
Old 03-15-2007, 04:47 PM
   someone correct me
zzzybil's Avatar
fairly sure i have the t3/t4 too ---- cept mine is trim 50.??.- someone correct me if i'm wrong....compression has the fancy ball bearing -mo betta version.........i think faster spoolin - longer lasting is my idea of what makes his better tho i don't know if its bigger too
i believe ours is known as the no frills pump king.....(. not pumpkin but best on pump gas ???)
..1st time i heard pumpkin and was NOT impressed......yep deaf duhhm and blonde
..and tho my boost was said to be @5-7 the gauge shoots straight to 10.......i think thats the edge of safety...for me anyway !.......they say 13 or so -on stock internals
i don't wanna be the one to find out !!.......its kinda scary enuff to be told the internal waste gate or bov was supposed to be set at 5 and creep to 7.......then find out by gauge i'm going to 10 ???..
..if i ever get this finished i'd like it to last as least as long as it took to build !!...j/k
if you don't mind and since you stated TRIM #... can i ask whats the trim part of the equation all about.....??........i know mine # anyway but what it means is a mystery
good luck with your project.....the more the merrier !.
..the more applications the less mystery....
WELCOME to the GROUP....
..keep us posted of your progress......
BOOsted 2.4
42lb injectors
3" tubes front to back
5-7 boost
38mm tial wastegate / bov
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
HPTUNING - the hard part !!!
JET-HOT 2000
aerologic egt kit
YEAH I DID THAT !
zzzybil is offline
Old 03-15-2007, 05:11 PM
Junior Member
zzzybil,
Here is a website that has some good information on turbo specifications: http://www.moddedmustangs.com/forums...rim-vt730.html
GRY GHST is offline
Old 03-19-2007, 07:25 AM
   thanks
zzzybil's Avatar
smaller trim # for smaller displacement engines ( unless internals )
basically the higher the a/r the higher the rpm spooling-.. smaller a/r spools faster and tops out sooner ?....
BOOsted 2.4
42lb injectors
5-7 boost
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
JET-HOT 2000
aerologic egt kit
YEAH I DID THAT !
zzzybil is offline
Old 05-30-2007, 12:30 PM
Jorgiuxxx's Avatar
well... there is long time ago that i posted the last msg... i am buying the turbo parts for separate. i actually have .
1.- Turbo manifold.
2.- FMU 12:1
3.- boost gauge Autometer Cobalt
4.- A/F ratio gauge Autometer Cobalt
5.- Turbo Garrett t3/t4 hybrid.
6.- CAI
7.- TurboXS BOV type H
8.- Intercooler piping Kit 2.5 "
9.- getting the intercooler, i cant decide wich model to get.
i think, Before July, i almost have done the project. Right now, my car is in the Service Maintenance on Pontiac Dealer beacuse there is a problem with the acceleration response, we dont know what exactly is this, they are making so many tests to find the problem, my car has been there 2 weeks, and keep there ..... if anybody can help me with this probem, it will be fine.
NOTE: right now my car just has installed a fujita CAI. it has been works properly from 5 months ago, but now the car make a big loug sound and the RPM goes very slowly ... i just need to fix this problem and then, get my intercooler for finally, begin the turbo instalation. =)
Old 06-02-2007, 10:16 PM
Jorgiuxxx's Avatar
Is the turbo too much big for the 2.4 L engine ? Do i have to lower the compression ? what size of complete exhaust system (turbo back) do you recomend me ? is 3" OK ?
Old 06-03-2007, 09:21 AM
   technical answers not my forte
zzzybil's Avatar
shabby asked / questioned your 55 trim ? did you figure that out ?... these guys here are pretty swoof.... ...great !! at providing answers and steering you to a link....
. i think if you return an answer for shabby - ??? he could reply better than me....... (that might come back to haunt you - ignoring his question ).. ..and effect more than you know !!..... if he said ??? .never heard of that size - make sure you know what you have ..
. a light flashes for ME !!!! when these guys say something !! if it is too big but you gave the WRONG number - ?? how can they answer your question ?
my advice is !!- answer the inducer /exducer question !!!..........you might see the TIP of the iceberg...... this is much more complicated a task than you think - theres a whole lot to it you don't SEE YET !! trust me ....
i looked at the link but didn't go outside and measure anything - ( mine is already "in" ) so theres no point now ..lol.. ( besides he didn't question trim 50 - he questioned YOURS )......hahaha if that lil bit of math scares you -- -- wait till you get to tuning ............
i wondered TOO if a different choice would have been better ?.........
other than me having 50 trim - i think we are using close to the SAME exact turbo ?.....no problem here.... i wish it spooled sooner than 3K ..lol.... but i ain't complaining..
find out what trim you REALLY have.........
....aj's fancier turbo fried in less than a month......i'm not sure if he ever got a answer or picked something different for the replacement..... ??
i'm justa noob - but theres a wealth of knowledge here !!
....i HAD to swap out the 2.5 for 3 inch tubes........ i am sure you NEED 3 inch tubes....NOT 2.5 !!!!!!!!... (((((.ask about that !!! )))))______ before you have to change them like i did........and certainly BEFORE YOU ORDER your i/c !!
i have 3 inch tubes FRONT to BACK......... i 'd hate for you to have to do the i/c and all your tubes TWICE.....or suffer issues with the wrong tubes LIKE ME
2.5 didn't work !! been there ! NO JOY !
you din't say anything about injectors ! ????? just curious
i didn't need the fmu 12:1 ......so far fuel pump is doing it's job........you might ask the stage 3 owners about fuel - sounds like you have bigger goals than me ........mostly just keep reading .........you might wanna check out a TUNING forum too.......make sure you know what you getting into.......cuz once you start its on like king kong - be ready to get up and monkey down !
wishing you moocho much a latte LUCK !
BOOsted 2.4
42lb injectors
5-7 boost
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
JET-HOT 2000
aerologic egt kit
YEAH I DID THAT !
zzzybil is offline
