GXP stock WHP - Pontiac Solstice Forum
Go Back   Pontiac Solstice Forum > Clubs, Events & Regional Discussion > Northeast > MASC/MASSC
Old 04-23-2011, 03:43 AM   #1 (permalink)
GXP stock WHP
Does anyone know what the stock Whp is for the GXP with an auto?
warrenhotrod1 is offline   Reply With Quote
Old 04-23-2011, 08:11 AM   #2 (permalink)
wspohn's Avatar
Lots of before and after dyno plots you can find with a search. As I recall, they are usually around 220-230 whp - the actual numbers vary quite a bit depending on dyno used, dyno settings etc.
Typical driveline loss is around 15% on the RWD and a bit less on the FWD cars.
1958 MGA Twin Cam (race car)
1965 Jensen CV8
1969 MGC roadster
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
Old 04-23-2011, 11:34 AM   #3 (permalink)
TomShadow's Avatar
Could any of you guys explain what a "WHP" is to us non-gearheads?
TomShadow is online now   Reply With Quote
Old 04-23-2011, 11:37 AM   #4 (permalink)
wspohn's Avatar
BHP = brake horsepower on an engine brake (dyno).
WHP is power measured at the wheels, on a chassis dyno. There is always some drive line loss through the transmission and differential.
1965 Jensen CV8
1969 MGC roadster
Bill in BC
Old 04-23-2011, 12:56 PM   #5 (permalink)
skline00's Avatar
Horsepower/Torque is advertised but really is measured at the Crankshaft (end of engine before transmission-driveshaft-differential). Since the Solstice GXP/Sky Redline is rated 260HP/260ft-lbs Torque at the crankshaft and since the car is rear-wheel drive, that power has to pass through the transmission, drive shaft and rear-end- differential and axles before the power goes to the wheels. Most cars are Dyno'd at the drive wheels so there is loss from the crankshaft numbers to the numbers arrived at for the drive wheels. I've seen dyno numbers as low as 200 Hp and @200ft-lbs of torque at the wheels. As wspohn points out, on a rear wheel drive car a 15% loss is the norm for real wheel HP/TRQ.
Lets do the math! 260HP/260 ft-lbs TRQ at the crank less the drive train loss (260x15%=39 -- 260-39=221 HP/221ftlbs Trtq.) So rear wheel HP/TRQ is closer to 220/220 Again these are averages.
I had the Trifecta Tune applied to our 07GXP 5 speed and had it dyno'd. Wheel HP was 280 and wheel TRQ was 321. This car has loads of power potential if tuned.
07 GXP 5mt DDM Backbone DDM ProBeam Trifecta Tune
skline00 is offline   Reply With Quote
