Old 03-27-2008, 03:23 PM
More Vids?
I want to hear more of that, first good sounding solstice IMO...
Impulsed7 is offline
Old 04-25-2008, 08:06 AM
This is proberly going to sound stupid! I am new to the 4 cyl, when you use Eaton MP62, is this the same one used by GM, and if it is how did you reprogram the ecm, and did you add some form of air to air or air to water cooler in fromt of the supercharger?
Thanks Tony-y
Tony-y is offline
Old 04-25-2008, 08:15 AM
RevmanII's Avatar
Tony, check out DDMWorks. They are a supporting vendor here and have their own little section. You can also check out their web site ddmworks.com. The sc used in the kit is the next generation of the one previously used in GM vehicles. Stage I does not use an intercooler and pushes around 4PSI. Stage II uses an intercooler and pushes around 8PSI. DDM reprograms the ECM as part of the kit. Hope that helps
EDIT: The IC is air to air
Mods: DDM Stage II supercharger. Solo Performance hi-flow cat, and SQR-2 catback. Norms rear fascia. MSD DashHawk.
RevmanII is offline
Old 04-25-2008, 08:58 AM
Supporting Tuner
Dave@ddmworks's Avatar
Thanks Revman!
Tony-y - If you have any other questions, feel free to ask, or give us a call at 864-907-6004
Dave - DDMWorks - South Carolina the home of the supercharged Kappas.
Dave@ddmworks is offline
