A couple of months ago I blew a gasket between my turbo and exhaust manifold....my bad because I didn't check the nuts which had backed off. Fixed that issue but then three weeks ago I noticed the car sounding more like a truck. Long story short, the exhaust manifold was somewhat loose and found that two bolts had broken off. I had torqued one off when we installed the turbo but these two that broke recently were at the other end of the manifold.
I had all the bolts replaced and during this found that the manifold itself is a little warped but with the new gasket and nuts/bolts, things seem to be fine for now. I will have to buy another exhaust manifold however
Are there stronger bolts/pins that can replace the oem ones ? Not sure if anyone else with an aftermarket turbo has had similar issues.
I suspect that there is a shearing effect going on during wot which may be causing this....just a guess.
I definitely am going to keep a close eye on them but I know I'm going to go thru this again and would like to do my homework before that day comes.
Any thoughts ?
Ottawa, Ontario, Canada
Team Solstice 2008
opjohn
I had the exact same issue about 18 months ago. When I looked at the stock manifold and then the turbo manifold I notice the holes in stock were significantly larger than on the turbo manifold. I also noticed the seperation cuts between each port were also touching each other.
It was shearing that caused this, as such I ended up modifying the turbo manifold by:
- Drilling out all but the two center most ones to match stock
- Recut (sawed) the seperation cuts between each port to provide more clearance (alllow for more CTE issues).
Never had the problem again.
Any thoughts ?
So I hit the nail on the head :-) Thought I might have been off base but thanks VIN2020. I'm going to have to look at the stock manifold again and then order a new turbo manifold and follow your suggestion. Alot of work but I can't afford to be doing this every year :-(
I wonder if the turbo manifold design needs to be re-addressed ? Must be others contending with this ?
Team Solstice 2008
I had the same thing happen to me just a few weeks ago. I had to send my manifold back to Hahn. They did some updates to it and it appears they actually cut a relief in the hole closest to the firewall and put more space between the flanges. Just sent the manifold back to hahn and they took care of it. I would get in touch with Aaron or Bill and see if your manifold has been updated.
Good Luck.
Clear
Mods
Hahn Turbo Stage IV with valvetrain upgrades
Clutch Masters Stage IV Clutch
Hahn High Flow CAT
Solo Performance Center Dual Exhaust with Norms Fiberglass Diffuser
I had this same thing happen about 18 months ago as well. I used a rotary grinder to reshape the holes in the manifold to look like the stock manifold and so far so good.
Wow...this does seem to be a bit more widespread than I thought. I'll have to contact them and ask them to send me out a new updated one. Mine is warped and not much use in modifying that one. If they are aware of updates like this, they should let us know.
I just spent a fair bit of money having this fixed and now I'm going to have to do it all over again.
I can do it myself but just don't have the time. This is my daily driver. Anywho....Thanks guys for all your feedback on this....especially clear !!!
I will contact them and see if they have changed their manifold design.
Thanks guys !
Good Luck.
Clear
Team Solstice 2008
I have to quit reading items like this. Every time I get ready to do something to boost my car, I hear another problem, not that I don't expect some issues, but this sounds like a major design problem. Well I'll wait and see what happens here.
It is not a major design problem, just room for improvement like any product has.
Sorry to hear you are going to remain on sidelines, and not have any fun with a boosted Sol (I cant imagine life that way). My personal recommendation is call Bill Hahn, and lay out the cash. You wont be sorry.
Thanks for the imput, I shouldn't be waiting to much longer,tuition for my daughter first. then something for the young one ( My Sky)
