Well, we've made a decent amount of progress in the last couple weeks. A big shipment of silicone and aluminum tubing showed up last week and Dad has been going at it with the tig welder. He's also working on hooking up the wideband. The LM-1 will let you simulate a narrow-band O2 for the stock ecu while you datalog the WB signal with EFILive. So, we're going to wire that in and start tuning the stock engine a little bit to get some practice with the software. The intercooler pump and radiator are next on the to do list.
I've been working on an engine model of the LE5 in a piece of software called Wave by Ricardo. It's a high end piece of software that many of the major OEMs use to reduce the amount of actual dyno testing they have to do. Once you have a good model, you can change cams, compression ratio, intake, exhaust, etc and see the changes it makes in torque, power, cylinder pressure, exhaust back pressure, bsfc, etc, etc. The main reason I'm doing it (other than I only have the software for a few more months before I graduate) is to see the effects of cam phasing on a supercharged version. Once I get the model dialed in, I'm going to mess with the cam centerlines to find out how changing the phase will affect power on a supercharged engine. Hopefully it will give us a good idea of what to do with the VVT when we start tuning on the actual engine.
More Pics!
Intake for M62:
MAF:
The first track day they've signed up for is April 18th & 19th, so we'll be pushing it to get done by then, but it should be doable.
