I got the the Stage IV kit put on last winter and wanted to wait till this winter for the addition of the high boost kit, wells now i got the kit and a few other things that im putting on also.
and i figured since im gonna have to take the head off ill get the turbo manifold and downpipe ceramic coated and the valve cover powder coated to add to the engine Blingness, and im also putting on a aluminium radiator from werks while everythings torn apart.
but heres my progress so far
Got the hood off , helps if two people are holding while one takes off the nuts
took the front fascia off
took off the pipes running to intercooler and throttle body, and removed intercooler and also drained the oil and coolant
before taking off intercooler
stock radiator
comparison
radiator removed
Hahn Stage IV Turbo 21psi
Werks Aluminum Radiator
Greddy Profec B Spec-II Electronic Boost Controller
Solo Street Race Exhaust
Hahn High Flow cat / Test Pipe
Spec Clutch and Flywheel
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
NOS intercooler sprayer
Dashhawk
BC Coil Overs
Hopefully!!!
totally revamp engine with forged internals
big brake kit(sorta scary at the moment)
the kit has a thicker multi layer head gasket, titanium retainers and seats with stiffer dual vavle springs, ARP head studs, manual timing chain tensioner and modified chain guide with offset adjustment bolts.
i think thats it.
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Hopefully!!!
i think thats it.
Was this kit an add on for the Stage III and doesn't it include a larger turbo and ECM programming?
Vin# 110166
DOD: 2/18/06
Aggressive, Ebony leather interior, everything except OnStar.
Hahn Stage III, powder coated pipes/valve cover, XPEL clear bra, lil chromies, painted calipers, caliper decals, centerpiece wheel decals, visor decals, 6" stubbie antenea, 20% tints, painted grills black, painted WS frame & behind the seats Aggressive, painted engine cover Aggressive, WOLO Bad Boy air horn, Solo SQR-2 dual tip center exhaust, Motegi DV5 wheels, Riken Raptor tires, Eibach springs.
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Hopefully!!!
got the intake manifold off today, was not to difficult expect for making sure all connectors are unplugged.
removed throttle body to free up some hand room
Back of manifold
Front
removed
clean shot at the starter and demon bolt for the transmission
these are the stock air box mounts that double as radiator mounts, with the turbo kit on the air box mounts get in the way somewhat so i seperated them by drilling through the two spot welds holding them together
__________________________________________________ ________________
contents of high boost kit
Multi-layer head gasket
valve spring
Titanium retainer
chain guide
valve seat
manual chain tensioner
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Hopefully!!!
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Hopefully!!!
well i tried to cut the radiator loom off at the house but i butchered it, so i gave it to one of my guys at my shop and they cut it flush off with the mill,
Top view
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Hopefully!!!
This is an awesome thread bterbeek ! This is my next mod so thanks in advance for informing us :-)
no problem
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Hopefully!!!
Can't wait to see the head off. looks like my next upgrade so I can get off my addiction to race gas.
i hear ya, i buy a 50 gallon drum of vp 109 that i keep in the garage
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Hopefully!!!
started taking the other side of the engine apart today
took of heat shield and groung wires
removed turbo to downpipe bolts, anyone elses gasket look like that
stud broke off a while back and ive been waiting till now to replace all of them
replacing with these
turbo off
took off the studs
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Hopefully!!!
