Ya my gasket looked like that, replaced it with another one supplied my Hahn, seemed to be a better one. Great walk through btrbeek.... So your replacing the studs on the turbo/exhaust manifold also ?
Ottawa, Ontario, Canada
The stud breaking is from a biggier issue, and based on your pictures the Manifold hole sizes will cause sheering of the stud bolts. Look at OEM manifold and then the turbo manifold you will see what I'm talking about.
hey vin,
i know what your talking about with the manifold holes being small, tomorrow im taking it in to work to open up those holes using a mill and surface grind the manifold to head flange smooth to remove the mill marks because they are deep enough to let exhaust gases to leak even though there is a gasket.
Hahn Stage IV Turbo 21psi
Werks Aluminum Radiator
Greddy Profec B Spec-II Electronic Boost Controller
Solo Street Race Exhaust
Hahn High Flow cat / Test Pipe
Spec Clutch and Flywheel
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
NOS intercooler sprayer
Dashhawk
BC Coil Overs
Inprocess
Bates Engineering - Sleeves and other neat stuff
big brake kit(sorta scary at the moment)
finally got all of the wires and connectors free!!!
so here are some pics
manifold
face
downpipe
head
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Inprocess
ok,took the manifold and downpipe into work , machined the face to a smoother finish and opened up exhaust ports a snitch
notice the different color in the steel, a little warpage
much smoother and flatter sealing surface now
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Inprocess
The current manifolds being sold by Hahn have been tweeked to incorporate larger holes as per the OEM manifold (not sure why they made them smaller to being with but ??) it is better that the earlier manifolds however.
Great job on reworking it bterbeek ! WOW !
thanks john , next its getting sent to swain tech for some ceramic coating!
got a little more off tonight , let me mention though that to get off the harmonic balancer you will need a flywheel holding tool so the crank does not rotate
part # is J-43653, you have to remove the starter to hold the flywheel
front cover off
crank sprocket
tool in place
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Inprocess
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Inprocess
Wow, looks like awesome progress so far. are you going to polish the ports and heads or are you going to replace them?
man i wish i had the resources to do this :P
I got the Moding Itch but im just a broke @$$ B!t<h! haha
Yup, We going to do a polish job and replace the valves with SuperTech Valves which of course are super de duper. This along with the rest of the stuff. Springs, Unobtanium (high grade stuff) retainers, Some ARP super head studs. and so on. GM super special thick headGasket. Oh yeah and changing the crankshaft sprocket gear to do something I don't totally understand but makes it work. The goal being to be able to boost up to 29 PSI, Oh my bad that's tire pressure. Ah I think it's 21PSI. on pumpkin gas. There of course is some more parts in the box. The goal is not to have parts left over in the Box that I got from my friends at Hahn.
Please don't try this at home folks as it requires factory manuals, special tools and special people. Not to mention many question from friends wondering why I keep taking my car apart.
Eibach sway bars
G51 LSD
Hahn high boost kit
Supertech valves
Ported and Polished
Dashhawk
BC Coil Overs
Inprocess
Thats cool, well i need to make some friends over at Hahn i guess as well
I work at GM as a designer, so all i can do is make stuff look purteeee.. lol but when it comes to taking stuff apart. .. um... i got to scratch my head I mean i know a few things but i really need to do some research into this stuff before i start playing with engine mods. Good luck , looks awesome so far.
