Help with choosing a turbo kit - Pontiac Solstice Forum
Go Back   Pontiac Solstice Forum > Technical Solstice Discussion > Mods - Engine 2.4 l Ecotec > Forced Induction 2.4 l Ecotec
Old 07-08-2012, 07:11 PM   #1 (permalink)
hi i have just bought a solstice about a week ago and im looking for a turbo kit, i was thinking about the hann stage 3, but im not sure what the car will hold with stock internals, transmission, rear end, axles. im wanting 300+whp any suggestions will help,
thanks
Hawk5392 is offline   Reply With Quote
Old 07-09-2012, 05:29 AM   #2 (permalink)
opjohn's Avatar
Stock internals will hold with a Hahn Stage 3, I've been boosting with that kit for over 80k. There are other kits to consider though....werks has awesome products and of course DDM superchargers. :-)
Ottawa, Ontario, Canada
2007 - 2.4 - Black - Hahn Stage 3
Too many goodies to mention :-)
opjohn is offline   Reply With Quote
Old 07-09-2012, 05:47 AM   #3 (permalink)
What motor is this for again? Also let's start with a key question, what is the application for your car, that way we can narrow down to what will better suit you. Will you be using the car for particular events? Or are you just doing car shows?
2007 Sky Redline: DDMWorks Charge Pipes & Intercooler, Solo Performance 3" Mach Shorty, ZZP S1 cams, Supertech Valve springs, BNR 2871, SPEC Stage 3+, Android "Torque" bluetooth RPD, HPT e47 tuned by TERM2. ???whp ???wtrq Dyno coming soon.
40rty is offline   Reply With Quote
Old 07-09-2012, 08:07 AM   #4 (permalink)
BlueMotorsport's Avatar
the N/A solstice features the 2.4L LE5
BlueMotorsport is offline   Reply With Quote
Old 07-09-2012, 09:04 AM   #5 (permalink)
OK, so its the 2.4L. Well I know the Weeks offers a few turbo alternatives and DDM as well. A Supercharger will put you right around the power your looking for. A turbo will definitely get you the power. I'll ask again what is the application for the car if there is one?
Old 07-09-2012, 10:05 AM   #6 (permalink)
Dave@ddmworks's Avatar
thanks
The answer depends on how much is 300+? If you will be right at 300-310hp how long everything lasts really depends on driving style and tires involved. The clutch is going to be a weak point at that power level and probably will not last. If you are doing track day events with sessions lasting over 30 minutes, I would make sure to watch your IAT's and also coolant temps if you plan on staying with the stock radiator.
If this is going to be something you will just run on the street with regular street tires and plan on staying right around 300 at the wheels, everything stock except the clutch will usually be fine.
Hope that helps,
Dave
Dave Michel
DDMWorks
Sales - 864-438-4949
Tech Support - 864-907-6004
WWW.DDMworks.com
Dave@DDMWorks.com
Dave@ddmworks is offline   Reply With Quote
Old 07-09-2012, 09:06 PM   #7 (permalink)
thanks for the input, im mostly wanting to keep it a street car but take it to the track every now and then, im more leaning towards the turbo but all i need is the kit and a performance clutch? and every thing should hold good
Old 07-09-2012, 09:50 PM   #8 (permalink)
thanks alot, so the stage 3 will just need a clutch and if i go with the hann stage 4 will i have to upgrade more than the clutch
Old 07-10-2012, 05:41 AM   #9 (permalink)
opjohn's Avatar
Yes you will, you will have to look at upgrading at least some of the internals (valve train for one) as valve float is a problem past 15 psi with out it. Hahn sells a kit for that as well as DDM (i believe). :-)
Old 07-10-2012, 07:10 AM   #10 (permalink)
wspohn's Avatar
You might have been better to have bought a GXP with all the work you want already done by the factory. If you see a well priced GXP, you might consider it.
1958 MGA Twin Cam (race car)
1965 Jensen CV8
1969 MGC roadster
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
Old 07-10-2012, 08:02 AM   #11 (permalink)
Yeap, we have valves, springs and retainers if you need them.
I have never been able to find an answer to this, but how did you know that you were getting valve float with the HAHN turbo kit? Did you raise the rev limiter above 7500rpm?
The reason I ask is that the 2.4L and the 2.0L engines use the same valve springs (GM part #90537032), and the 2.0L engines will take high 20's pressure and 7500RPM.
Thanks,
Dave
Dave Michel
DDMWorks
WWW.DDMworks.com
Dave@DDMWorks.com
Old 07-10-2012, 12:51 PM   #12 (permalink)
is that for the stage 4 or will the the stage 3 need the valve work to?
Old 07-11-2012, 05:42 AM   #13 (permalink)
opjohn's Avatar
Thanks,
Dave
Hi Dave !
Back in the day I was pushing my car somewhat, trying to see what PSI levels I could attain using the stage 3 kit from Hahn. There are several reseaons why I couldn't get past 16 psi but one of the big reasons was Valve Float. I confirmed this with Bill Hahn Jr. but not being a tech like you are, I can't give more detailed info other than that. Could be the entire recipe (tune, air flow plumbing, size of turbo, fuel delivery method) but getting past 16 psi with the stage 3 kit wasn't sustainable. I regularly push it to 15ish with no problem however. My rev limiter is set to 6200 as Hahn felt that was best (less engine wear and power was more than ample).
Take it easy Dave !
BTW; your stage 3 clutch has worked a treat !
Old 07-11-2012, 05:46 AM   #14 (permalink)
opjohn's Avatar
Stage 3 could benefit from it but is not necessary. Stage 4, it is strongly recommended.
Old 07-11-2012, 09:43 AM   #15 (permalink)
Thanks alot everybody i guess its time to start saving lol
