having built/rebuilt an l61 and an le5 I can offer a bit of insight into the differences between the obvious bore/stroke and lack of vvt on the l61.
the l61 only has one cam pickup, therefore the heads cannot be swapped without modification. the LE5 has an oil cooler on the back of the motor, L61 does not. the le5 also has larger valves I believe. L61 has an SAI system, there are extra holes to force air into the head and down the exhaust via the top of the exhaust manifold, the LE5 lacks this.
other than that, the motors are identical as far as I could tell. bearings, main bolts, head bolts, valve springs and retainers, etc etc etc.
the LE5 has very thin cylinder sleeves. the reason the L61, LNF, and LSJ blocks are able to hold so much power is nice thick sleeves and a shorter stroke putting less stress on the crank.
we will see how much abuse our 2.4L crankshafts will take when mine and the HRC car are completed.
06 Mysterious
builtttttttttttt
>400 whp here we come
