Originally Posted by
ssdragon
yeah i have no throttle linkage its all fly by wire. and i dont want any CEL's at all so I hope this guy from pcmforless and hptuners will be able to overcome this job.
if your not doing the tuning yourself, your best bet is to find someone local to do the tuning for you. The main reason being that your always going to have problems and minor changes. Just make it easier on yourself and have someone you can goto in a pinch.... thats the only tip i have for you.
If you want examples of methods other then HPtuners, do a seach for boostedsol's setup. He used LS1edit for the spark/maf/PE tuning and then used an extra-injector-controller for boost. Its agurably a better way to do it, but i prefer HPT.
If your PSI goals are under 12psi you dont need to worry about alot of things, and as long as your turbo isnt so small your getting huge amounts of partial throttle boost your tuner shouldnt have any issues with tuning.
And dont worry about the multi dementinal 5d VE vortex off alpha-omega quadreant 5... its some crazy advanced stuff you dont need to rake your brain on. Just stick to the normal routin, maf/pe/spark.
