I've been reading a bunch of stuff about lean conditions, detonation, destroying internal engine parts, etc. If this is occurring out there, how come the ECM's aren't throwing lean burn codes, etc. before it gets to this point?
Mysterious/Ebony
Vin # 9126
DDM Stage II, DDM Pro-Beam, High Flow Cat, KS1, Lil Chromies, 5" Stubby Antenna, Black Center Wheel Caps, Dimming Home Link Mirror
Fully Loaded Except for XM and On-Star
Most engines are destroyed during WOT runs, this is when the stresses are at their max. The ECMs will not throw a lean code during WOT. They are only monitoring Closed loop operations. For a lean code to trip, the LT & ST trims must max out past 20% error for a continuous period of time. In our ECMs Fuel trim monitoring and correction are disabled during WOT or whenever PE(power enrichment) mode is active. Also, stock Narrowband O2 sensors are not sensitive enough of the correct operating range.. They on read Rich or lean...no in between. The only two ways to monitor the safety of an engine at WOT are, EGT (exhaust Gas Temps) or Wideband O2 sensors. This applies wether it's a NA, Turbo, Supercharged, or Nitrous'd engine.
__________________ Randy Carter - Product Manager www.DDMWorks.com
I've seen the terms used and have an idea what they mean, but could someone provide definitions and an explanation of how they all work?
LT trim
ST trim
Narrowband
Wideband
When does it transition to PE mode, wide open throttle only? Is PE mode control a function of how the ECM is programmed (open loop)?
I've heard the ECM's "learn" and adjust to actual operating conditions - octane, small mods, etc. What is the limitation of how much the ECM can compensate???
Thanks!
P.S. If this is too much to answer, a reference to an article would be great. Just trying to understand how it all works. We have 3 sensors - air flow on the intake, and two O2 on the exhaust. What else provides inputs to the ECM - Throttle body position, RPM, Air Temp,....
2.4L SKY
Redline Dual Exhaust
DDM Stage II Intercooled SuperCharged
Vin #401, delivered 4/06
Silver Pearl with Leather interior
Spoiler
Chrome Wheels
Clear Bra
Monsoon 6CD
Heated Seats
Extra Trunk Space!
Stubby
LT trim
ST trim
Long term and short term trims are corrections the ECU makes for fueling errors it detects during closed loop fueling mode. This is at light load / part throttle operation and usually limited to lower RPM's. The open loop fueling mode (WOT, high RPM high load) then uses thes corrections but does not actually determine if they are delivering the right amount of fuel. Open loop specifically uses the long term trim. SOOO if you have a recent mod, and the long term trim has not corrected for it yet, you will see no correction at WOT. Hence all the lean engine blowing up. Edit: As randy said, PE negates the fueling correction. Narrowband
Wideband
Wideband 02's detect (over there voltage range) a complete air fuel ratio spectrum. "narrowband" or Switching 02 sensors only detect whether the air fuel ratio is greater or less than stoichiometric (14.7:1). The specific amount over or under is not known, so the ECU corrects slowly, usually arriving at a correction within the 20% maximum limitation. IF it does not arrive at a correction within the 20%, the Check engine light is turned on. When does it transition to PE mode, wide open throttle only? Is PE mode control a function of how the ECM is programmed (open loop)?
The ECU is programmed for a lot of different fueling applications, which are assigned based on priority, simplest form being whichever one is richest, and the ECU chooses an air fuel ratio from that. PE is activated typically at high Load / Higher RPM situations. This table is often used by tuners (logic of which is debateable) to adjust WOT fueling for mods. I've heard the ECM's "learn" and adjust to actual operating conditions - octane, small mods, etc. What is the limitation of how much the ECM can compensate???
Yes there is a limit, but we don't know what it is. You can trick it into all kinds of stuff... pressure regulators on boost solenoids, fake 02 sensors, etc. etc. etc. But that really has nothing to do with changing the calibration and aren't very robust solutions.
LT trim
ST trim
Wideband
Great explanation. Thanks!
2.4L SKY
Spoiler
Chrome Wheels
Clear Bra
Monsoon 6CD
Heated Seats
Extra Trunk Space!
Stubby
