Originally Posted by
JPM
That's good enough to get the idea across. Definitely a doable design. I can even get carbon fiber print leather for the black areas if you'd like.
I can go about this two ways.
1. Resculp the foam in the seat and re-align the attachment points so to more closely resembles the Zonda seat. It will also allow me to make the white rectangles actual rectangles and consistant in size and shape. This is definitely the more expensive route as seat reshaping is not an easy task and would probably end up being close to double what I charge for a set of seats. It would also be the most custom looking.
2. Work with the pattern that's already there and just add the white sections to the current seat design. It will look similar, but the overall seat pattern will be the same as stock with the same stitch and seam lines. This would be slightly more than what I normally charge for a set of seats.
Lets go route 1. Do you need a color sample? I will be using SEM phantom white for various pieces of recoat. Pm me a start-up price so I can send you some cash for materials. Wife said i can do it for my birthdate!!! This piece will turn some heads at sema.
