Solstice Service - Battery Replacement Procedures
48K views 17 replies 14 participants last post by  stevebot39
#1 ·
Because there has been speculation, here is the procedure:
Battery Replacement
Removal Procedure
Disconnect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Remove the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Lower the vehicle.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable (1).
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the battery hold down retainer and bolt. Tighten the bolt to 25 N·m (18 lb ft).
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the positive battery cable (1).
Tighten the positive battery cable bolt. Tighten the bolt to 17 N·m (13 lb ft).
Close the positive battery cable connection cover.
Install the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
#5 ·
On a side note, if the black thing that covers the tires is the "wheelhouse liner", that desciption is about correct. It is truly a "liner," because it is very soft and plyable. You can literally push it down so it touches the tire, it's almost squishy. After talking to the CCC at the track they made this piece out of this soft material to keep the weight down.
#6 ·
stang said:
You take the front fender off to change the battery? That's interesting. :crazy:
The way I interpreted the instructions was to remove various fender brackets....not the fender itself. Either way, it looks like a real pain...I'd probably take it to one of those battery stores that do free install with the purchase since I would imagine the dealer will charge several hours in labor.
#7 ·
careful of the free installs..too...if they cant simply undo the terminal leads and lift the battery from the bracket...its not free.....I was in sears the other day....and they were charging a fee to replace a battery in the new style beetle....because the salesman stated it was more labor intensive due to the battery location in the car.....Not sure I wouldnt let the dealer do it...maybe one of those fixed priced items......a good service department will do that..vice selling the item and charging a labor charge for installation as well.
#8 ·
But still removing all those brackets that place the fender in its proper alignment may cause misalignment when retightening.
#9 ·
I will post the jump start instruction later, tonight.
Keep in mind that this isn't a fender in the normal sense of the word. It is just the trapazoid shaped panel behind the wheel and in front on the door.
#16 ·
I have no issue aliging fenders.many arnt right in the first place....although mine was pretty close. & I didnt see how the battery could come out by removng the inner fender plastic. there is still a brace in the way and to me looked like the fender had to come off to remove the brace... now if gm didnt put the diagonal brace on the inner fender structure ( or make it removable) that structure wouldent need removing witch would make it a lot easyer.and a lot less adjusting would need be done.
#18 ·
Batteries are fickle. My original lasted 9 years with 2 owners and two locations, NJ and FL. The replacement lasted less than one year here in AZ. Firestone replaced it at no cost by removing the “fender”, but failed to align it properly.
