Bad, Bad, Bad, Bad Vibrations - Pontiac Solstice Forum
post #1 of 30 (permalink) Old 03-15-2009, 02:24 PM Thread Starter
I have never been in any other Solstice than my own, so I am wondering if anyone else has a bad vibration problem around 80 mph? I had the tires balanced twice, so at this point I am wondering if I have a bad tire, loose body panel, driveshaft issue, or if these little cars just get buffeted by the wind and get the shakes. The problem is non-existent below 70 mph, starts to show up around 75, and will make you angry around 80. I have the Monarch J2 Staggered 18" Wheels with Goodyear Eagle F1 All-Seasons. Any feedback would be very much appreciated as I try to remedy this issue.
thanks
2007 Cool GXP, 5spd, all the bell & whistles except Skynet, I mean OnStar
PCM For Less Tune
DDM Backbone
SOLO GXP Mach
SOLD - 06/05/2010
Replaced my 2006 Jeep Rubicon http://www.clarioncreative.com/jeep/after0003.jpg
folkxrock is offline
post #2 of 30 (permalink) Old 03-15-2009, 03:03 PM
thanks
Had mine on the highway for a 2 hour back and forth trip and had no problems with any type of vibrations at 80.
stevechristian is offline
post #3 of 30 (permalink) Old 03-15-2009, 03:09 PM
fivespokes's Avatar
mine smooth too at 75-90.. sorry
I had a little missing early on at these speeds.. Blow it out by getting the boost up to the teens in 5th. or use V-power or a gas additive..
2007 GXP mysterious (sold.. I sorry)
leather, monsoon, 6 CD, headliner, sport pedals, polished aluminum, custom front grille, GMPP stage II upgrade, GMPP exhaust, K&N drop-in, stubby antenna, Kappashield, XM, no front plate (2 tix so far)
Vin#12,6404
2006 mysterious # 5330 (SOLD)
NASSOA # 87
fivespokes is offline
post #4 of 30 (permalink) Old 03-15-2009, 03:22 PM
LiquidPT's Avatar
Sounds like an alignment issue? Could also be uneven tire wear (usually cause by bad alignment or track use), or even uneven tire inflation.
LiquidPT is offline
post #5 of 30 (permalink) Old 03-15-2009, 03:26 PM
Mac
Mac's Avatar
I would check to see if the wheels/rims are true. they could be balanced and not be true. A dial indicator set to the rim edge while off the ground will tell if its out of round. The rim could be bad even if new, or a tire could be blem as well. Have you ever hit a curb or a pot hole that might have bent a rim or spindel/axle?
Mac is offline
post #6 of 30 (permalink) Old 03-15-2009, 03:29 PM
My guess would be tires, rims or balance.
EnviousSol is offline
post #7 of 30 (permalink) Old 03-15-2009, 03:40 PM
madmods's Avatar
No, you got a serious problem here. Especially if you have had you wheels balanced. You should not even vibrate into the 3 figures. Time to have your dealer take a ride in it.
Fast & Furious 4 solstice:
Solstice parted out and I'm off the forum. Pm me if you need something.
madmods is offline
post #8 of 30 (permalink) Old 03-15-2009, 03:40 PM Thread Starter
No damage to the wheels or tires (That I know of). I am the only one that drives the car, except when it is in for service. I am pretty sure the car has had this issue since I bought it. I put the wheels/tires on pretty early, so I can't say if the problem did or did not exist with the factory wheels/tires.
I am starting to wonder if I have a bad tire. I purchased through Discount Tire, but their closest location is about 3.5 hours away from me. Anyone have a good idea on how to go about solving/resolving this one?
PCM For Less Tune
DDM Backbone
SOLO GXP Mach
SOLD - 06/05/2010
post #9 of 30 (permalink) Old 03-15-2009, 03:44 PM
May want to check your front axle nut to make sure it's tight. These cars are known to have the nut loosen up when cornering really hard over a long period of time. I doubt if this is the problem...but worth a check anyway.
07 2.4L/5-Spd, Mysterious, Premium & Preferred Pkg, Remote Keyless, Fog Lts, AM/FM/CD
MODS:
DDM S/C Stage II, Exedy Stage II Clutch & Lightweight Flywheel,
DDM Probeam, Eibach Front & Rear Anti-roll bars, 3.73 Rear w/LSD,
Kappasphere Lowering Springs, Koni Sport Adjustable Shocks,
B & B (Billy Boat) Catback Dual Exhaust, Hawk HPS Brake Pads
GXP Dual Exhaust Valance
245/40/18 Dunlop Direzza Sport Z1 Star Specs
Dashhawk, Stubby Antenna, Custom Alignment
"Maine"-iac is offline
post #10 of 30 (permalink) Old 03-15-2009, 04:17 PM
compression's Avatar
I'm wondering if you need HUB rings for your rims. I'm not sure if the wheel you bought is Hubcentric. But I had to put plastic wheel hubs in for at least 2 sets of my wheels.
The new build is DONE.
Engine-Check
Turbo set up-Check
Suspension-Check
Brakes-Check
Seats-Check
Paint-Check
compression is offline
post #11 of 30 (permalink) Old 03-15-2009, 05:15 PM
GS Stage 1's Avatar
I know this idea is a pain in the butt, however, changing back to the factory rims/tires would tell you if the problem is wheels or car.
GS Stage 1 is offline
post #12 of 30 (permalink) Old 03-15-2009, 05:34 PM Thread Starter
Yeah, I would try that first, but I sold the factory wheels and tire - why would I need those sitting around in the garage - hahaahha
PCM For Less Tune
DDM Backbone
SOLO GXP Mach
SOLD - 06/05/2010
post #13 of 30 (permalink) Old 03-15-2009, 05:41 PM
numbbers's Avatar
Smooth as glass at 115.
Thanks, Dave Russell
Mallett #33
VIN #1G2MB35B27Y106697
Platinum Pearl over Deep
Ebony Leather
Custom Arelli
numbbers is offline
post #14 of 30 (permalink) Old 03-15-2009, 05:54 PM
Critterman's Avatar
Other things to check is your drive shaft. Gizmo lost 3 nuts, and two bolts out of the six holding he driveshaft to the transmission.
DDM stage III w/custom CAI
DDM Stage III Upgrade here
Critterman is offline
post #15 of 30 (permalink) Old 03-15-2009, 06:13 PM Thread Starter
That crossed my mind as my car did have the rearend recall fixed before I purchased it. Also wondered if maybe they did not get the drive shaft back in the correct position and it is a DS balance issue.
PCM For Less Tune
DDM Backbone
SOLO GXP Mach
SOLD - 06/05/2010
