Check your frame for rust - Pontiac Solstice Forum
 7Likes
  • 1 Post By Devoking
  • 1 Post By ChopTop
  • 2 Post By Sting Ya
  • 1 Post By Sting Ya
post #1 of 11 (permalink) Old 04-15-2019, 08:31 AM Thread Starter
Devoking's Avatar
I discovered a section of rot on the right rear section of my frame.
This is an 06, and it has been driven. All kinds of weather, with over 120,000 mi.
I have since, taken a real good look at the rest of the frame and it seems to be just this one spot.
The brake line in bottom right side of pic gives a location perspective.
Was a Pair-a-Sols!
Devoking is offline
post #2 of 11 (permalink) Old 04-15-2019, 08:36 AM Thread Starter
Devoking's Avatar
My Son knew someone that does lots of his own fabrication and this has been fixed.
First he located good metal, cut out section and sprayed rust inhibitor inside.
ID:	94997   Click image for larger version
Sting Ya likes this.
Was a Pair-a-Sols!
Devoking is offline
post #3 of 11 (permalink) Old 04-15-2019, 08:38 AM Thread Starter
Devoking's Avatar
Put in a flush patch.
ID:	95001   Click image for larger version
ID:	95003   Click image for larger version
Was a Pair-a-Sols!
Devoking is offline
post #4 of 11 (permalink) Old 04-15-2019, 08:41 AM Thread Starter
Devoking's Avatar
Then laid a larger patch over the top. Then finished it off.
ID:	95007   Click image for larger version
Was a Pair-a-Sols!
Devoking is offline
post #5 of 11 (permalink) Old 04-15-2019, 12:41 PM
ChopTop's Avatar
I've asked about Kappa rust points in the past, but I think this is the first post documenting rust repair. Good job.
ChopTop is offline
post #6 of 11 (permalink) Old 04-15-2019, 01:21 PM
Sting Ya's Avatar
I second that !
Sting Ya is offline
post #7 of 11 (permalink) Old 04-15-2019, 04:25 PM
Amigo's Avatar
Too bad our hard earned dollars have to turn into that cancer. It seems that there should be many ways to prevent or at least stave off this kind of rot this early in the life of that car.
Nice repair job though !
2007 GXP Mysterious
Rear Spoiler
Painted calipers
Cup holder console DDM
2008 SHELBY GT500 Black
rear window louvers
side window louvers
power stow lic plate
duo pod pillar gauge
billet dash plaque
billet engine caps
Amigo is offline
post #8 of 11 (permalink) Old 04-15-2019, 04:34 PM
Sting Ya's Avatar
I don't drive my car from November till May because of the salt they use on the roads here in Ohio which ends up causing rust issues no matter how hard you try to keep it clean . Every spring I spray the chassis and components with WD 40 and wipe off any excess my car still looks new it's a pleasant way for me to spend a couple of hours knowing I'm prolonging the life of my car . As for my daily driver I have had my car undercoated with a Canadian product Corrosion Free it's a gel like substance that penetrates and protects ,it does not drip ,dry , smell and stops any existing rust ,after 3 Ohio winters my Grand Marquis still looks like new underneath . I do my own maintenance and it's really nice to remove nuts and bolts that are not rusted to the point that you have to use heat to loosen them up . I would recommend this stuff to anyone I've had a few of my friends who have this done to their cars and everyone swears by it .
Amigo and ChopTop like this.
Sting Ya is offline
post #9 of 11 (permalink) Old 04-15-2019, 09:19 PM Thread Starter
Devoking's Avatar
I agree. The area on mine that rotted is where they did a stitch type weld along that seam. If you look close the metal puckers a little bit between those welds. Best I can figure is that those two puckers were larger than the rest and held moisture and allowed it to seep in. Will never know for sure but it does seem like it happened way too early in the life of the car.
Amigo likes this.
Was a Pair-a-Sols!
Devoking is offline
post #10 of 11 (permalink) Old 04-16-2019, 10:54 AM
ChopTop's Avatar
Thread hijack. I believed I checked into this product because if it's good enough for Canada, but do they use salt? Also, is this the stuff where you have to have it reapplied every few years in order to maintain it's warranty? Also, I don't think they have any vendors in Michigan.
ChopTop is offline
post #11 of 11 (permalink) Old 04-17-2019, 08:06 AM
Sting Ya's Avatar
Chop don't think that this is really a thread hijack as it pertains to eliminating the very problem that the OP has just my opinion . The first video that I ever saw for this stuff was filmed in Canada and if you go on their website they state "protection from salt and brine " . The guy that has done mine an authorised dealer recommends having it reapplied every 18 to 24 months depending on how much you drive . When I first read up on this there was a report by the Canadian Government that did a comparison test of different rustproofing products to use on government vehicles and this is the one they chose . Out of all the rustproofing products I used on my cars over the years this is by far the best .
ChopTop likes this.
Sting Ya is offline
Similar Threads
Canadian Rust Check Sting Ya General Off Topic 17 05-05-2015 09:01 AM
Rust on the rotors SolsticeDesire General Tech, Platform Common Issues & Solutions 27 01-04-2008 10:05 AM
Rust Proofing restlessone General Solstice Discussion 9 03-09-2006 03:15 PM
axles with rust RODEO General Tech, Platform Common Issues & Solutions 23 01-26-2006 05:06 PM
Rust Proofing dylan01 General Off Topic 2 11-21-2005 05:08 AM
