Cleaning engine bay - Pontiac Solstice Forum
 6Likes
  • 1 Post By chickenwire
  • 1 Post By JohnWR
  • 2 Post By wspohn
  • 2 Post By Sting Ya
post #1 of 14 (permalink) Old 04-09-2019, 01:47 PM Thread Starter
Cleaning engine bay
Any problems cleaning the engine bay what electronics should I look out for?
wallace is offline
post #2 of 14 (permalink) Old 04-09-2019, 01:53 PM
chickenwire's Avatar
Search is your friend, my friend. Click the link below:
https://www.solsticeforum.com/forum/...detail-153506/
Sting Ya likes this.
chickenwire is offline
post #3 of 14 (permalink) Old 04-09-2019, 02:13 PM
Sting Ya's Avatar
Do you mean using some type of power washer ? if using one no need to have it set on full power .The electrical connections are waterproof after all these cars are built to be driven in the rain .If you have an aftermarket CAI I would wrap the filter element in plastic wrap ie: Saran Wrap or aluminum foil . I would not use any type of caustic cleaners Simple Green works very well for this and you don't have to worry about damaging the paint or plastics . When I'm finished rinsing things I take a hand held leaf blower and give everything a good blast to remove any water then I start up the car and let it run for a bit to dry things off .
Sting Ya is offline
post #4 of 14 (permalink) Old 04-09-2019, 02:42 PM Thread Starter
Thanks a lot
wallace is offline
post #5 of 14 (permalink) Old 04-09-2019, 03:04 PM
I agree with Sting Ya except to say that I would not use a pressure washer at all. The connectors are water resistant, but not necessarily under extreme pressure. Normal hose pressure is about all I would use.
JohnWR is online now
post #6 of 14 (permalink) Old 04-09-2019, 07:44 PM
Saveaux's Avatar
Saveaux is online now
post #7 of 14 (permalink) Old 04-10-2019, 05:23 AM
^^ this. Weather resistant, not "water proof".
post #8 of 14 (permalink) Old 04-11-2019, 06:14 AM
ChopTop's Avatar
The hot ticket is dry ice cleaning, it doesn't affect engine bay electronics. But you have to live somewhere where the service is offered.
ChopTop is offline
post #9 of 14 (permalink) Old 04-11-2019, 07:18 AM
Certainly better than a pressure washer, but I still don't like the idea of pointing a high-pressure jet at electrical connectors.
I am still most comfortable with spraying everything with Simple Green or car washing soap, then rinsing thoroughly with hose-pressure water.
post #10 of 14 (permalink) Old 04-11-2019, 07:47 AM
showtime's Avatar
I recently watched a great video on cleaning the engine bay and the person suggested disconnecting the battery. Anyone do this?
showtime is offline
post #11 of 14 (permalink) Old 04-11-2019, 08:01 AM
Probably not a bad idea- plus you can clean under the battery if you remove it- I'm trying to make a steam cleaner out of an old kettle right now to clean my engine bay!
Zinger is offline
post #12 of 14 (permalink) Old 04-11-2019, 08:42 AM
wspohn's Avatar
Have you ever removed a Solstice battery? Not a trivial job, and certainly not one I'd undertake just to clean under it where no one will ever see anyway.
Sting Ya and nauticalm like this.
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #13 of 14 (permalink) Old 04-11-2019, 09:03 AM
True, but I'm going to remove mine though because my fender on the rocker is misaligned as the previous owner didn't match up properly when he replaced the battery
Zinger is offline
post #14 of 14 (permalink) Old 04-11-2019, 09:14 AM
Sting Ya's Avatar
I've never disconnected or removed my battery while cleaning an engine compartment unless I was replacing a battery no need to . As for my comment about using a pressure washer I live in a semi rural area so the water pressure is not the greatest as mentioned above when I use the washer I have it set at a medium setting and I try to avoid spraying it directly on electrical connectors . The Delphi connectors on our cars are pretty water tight and as CW mentioned they are "weatherproof " my mistake one thing that I do when disconnecting an electrical plug before I reconnect it I always give it a shot of dielectric grease to keep any moisture and corrosion out . Another thing I do is give all my rubber hoses and plastic covers ( inner fenders on the Solstice ) a wipe down with a rubber/plastic protectectant I like Lucas or Griot's Garage products .
Amigo and joybill44 like this.
Sting Ya is offline
Similar Threads
engine bay cleaning / detail ? sirwm Car Care and Detailing Forum 18 05-10-2018 09:57 PM
cleaning engine sirmeili General Tech, Solstice GXP Specific 28 04-18-2011 10:08 PM
Cleaning the engine and now engine light is on turboman808 General Solstice Discussion 11 07-03-2010 12:22 PM
Engine cleaning not working!! Berserk303 Car Care and Detailing Forum 10 03-06-2008 06:03 PM
Engine Cleaning mvsoske Car Care and Detailing Forum 14 10-09-2007 02:52 PM
