Correct Hardware for Tire Balance - Pontiac Solstice Forum
 4Likes
  • 2 Post By phil1734
  • 1 Post By phil1734
  • 1 Post By Sting Ya
post #1 of 15 (permalink) Old 03-26-2019, 05:57 AM Thread Starter
Hello,
I recently had my tires balanced, and the shop use stick on weights. Yesterday I discovered one strand of these weights lying on the floor of the garage.
What are some better / correct approaches to balancing Solstice tires?
Thank you for your help.
ShortLeash is offline
post #2 of 15 (permalink) Old 03-26-2019, 06:28 AM
phil1734's Avatar
A different shop.
There are only two forms of wheel weights I'm aware of. Stick on and clip on, and you don't want to be putting clip on weights on solstice wheels. If the stick on ones fell off it's because whoever installed them didn't give a crap about the job they were doing. They normally don't even come off when you want them to.
Sting Ya and Rphillips66 like this.
2007 Solstice GXP
#3 ASP, DET and NWOR SCCA
phil1734 is offline
post #3 of 15 (permalink) Old 03-26-2019, 06:37 AM
Tru dat, if done properly they require a chisel or similar to remove, I've been using them for over 20 years and never had one fall off, like phil1734 said- they didn't give a crap-lazy!
Zinger is offline
post #4 of 15 (permalink) Old 03-26-2019, 08:27 AM Thread Starter
Thanks for the feedback. I also wonder if the surface condition of the wheels is a factor. My wheels have what looks like surface corrosion (?), that could possibly be eliminated with cleaning and polishing (?). Maybe this would allow for better adhesion of stick on weights (?).
post #5 of 15 (permalink) Old 03-26-2019, 09:16 AM
phil1734's Avatar
Do you have chrome or painted wheels? And did the chrome/paint come off with the weights?
Otherwise you have to have a lot of dirt, dust or corrosion on wheels before they won't stick, and again - the tire shop should have cleaned that up or at least told you they had a concern before they gave the car back to you. Even a modest wipe with a dry rag and most weights will stick for way longer than the life of any tires.
Sting Ya likes this.
2007 Solstice GXP
phil1734 is offline
post #6 of 15 (permalink) Old 03-26-2019, 10:20 AM Thread Starter
I have the polished aluminum wheels (not painted).
post #7 of 15 (permalink) Old 03-26-2019, 02:28 PM
Rick Bennett's Avatar
the shop should use a cleaner to clean the area that they are placing the weight in (I use brake clean, spray it on a clean rag )
Rick Bennett is offline
post #8 of 15 (permalink) Old 03-26-2019, 02:41 PM
mjpxd's Avatar
They should not fall off, take it back to the installer and have them rebalance the tire and check the others for loose weights.
2008 NA, factory chrome wheels, power windows, wind deflector, OnStar.
Midland, GA
mjpxd is offline
post #9 of 15 (permalink) Old 03-26-2019, 09:15 PM
Sting Ya's Avatar
Lacquer thinner and some steel wool does wonders
Rick Bennett likes this.
Sting Ya is offline
post #10 of 15 (permalink) Old 03-27-2019, 05:21 PM
Anyone try tire beads ?
I have 5hem in my harley and see they are used for all types of tires but not sure if they would mess with the tmps
Cityboy is offline
post #11 of 15 (permalink) Old 03-27-2019, 06:37 PM
The Counteract website says they are compatible with TPMS, but only lists applications for trucks, motorcycles, and off-road. The calculator will not accept our tire size, either.
post #12 of 15 (permalink) Old 04-06-2019, 07:15 PM
I dont know if lead weights are still around or if there all steel now, some of my wheels have led and some steel. I agree the give-a-****less person who did it did not clean them first. or not conform them to the wheel's arc. I bought a box of lead stickeys about 10 years ago for my light weight forged vw wheels. Im gladd I bought the box!!! the steel weights can rust.
on another note....my wheels are the polished wheels. are they clear coated??they dont really look like they are but...this is my first go round with factory non color painted aluminum wheels. rsx wheels painted, and my bug wheels are 6061t6....a bitch to keep clean& polished but look like a mirror. and my chrome wheels are...clear coated....foggy,pealing..and well over 20 years old.
so are my solstice wheels clear coated or just polished?
marksbug is offline
post #13 of 15 (permalink) Old 04-06-2019, 07:58 PM
I havent done it on the Solstice, but on my rods when I would get them balanced, I always put duct tape over them.
YO MUDA is online now
post #14 of 15 (permalink) Old 04-07-2019, 11:52 AM
wspohn's Avatar
That's what we used to do on the race car wheels, and they never came off. You do have to ensure that the weights aren't stuck onto a layer of corrosion on an alloy wheel....
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #15 of 15 (permalink) Old 04-07-2019, 01:56 PM
phil1734's Avatar
Metal foil tape (the stuff you actually put on the ducts in your basement) works well and blends into chrome/polished aluminum better.
But again, these things should never really come off. Racecars do it because of the excessive heat and fluids that can get on them and there's a certain level of aircraft-level no-failure-is-acceptable attention to detail.
2007 Solstice GXP
phil1734 is offline
Similar Threads
LEHMAN's Hardware (Amish Run) Friday June 11th only druid-2 National Events 3 04-25-2010 09:21 AM
Picture of top hardware Venice Solstice Forum Site Issue Forum 2 08-01-2009 10:28 PM
Data acquisition hardware... what's good? rlhammon Autocross and Racing Discussion (Solstice/Kappa) 26 03-06-2008 10:00 AM
linkage from roof hardware snapped off Kid-Colt General Tech, Platform Common Issues & Solutions 11 07-03-2006 07:48 PM
License Plate Hardware trobert General Solstice Discussion 4 06-22-2006 08:54 AM
