Differential Leak - Pontiac Solstice Forum
post #1 of 5 (permalink) Old 05-24-2019, 06:38 PM Thread Starter
Differential Leak
I have a leak on the left side of the differential. Assuming it is a gasket.
Being new to working on the Solstice, I was wondering if this is something I could replace myself or if it is a major overhaul. Haven't gotten underneath to look at it real close. Wondering if others have had this problem and how they fixed it. Thanks
grizhlr is offline
post #2 of 5 (permalink) Old 05-25-2019, 06:33 AM
SolCal's Avatar
There was a recall for the pinion seal. Check to see if it was done on your car.
SolCal is online now
post #3 of 5 (permalink) Old 05-25-2019, 06:42 AM
Devoking's Avatar
Leaking on one side would indicate the axle seal.
Just had mine changed while doing other work.
The left side ended up with a bad seal.
Since it was an AC Delco seal, the dealer changed it out as warranty work.
The no charge bill, was for $146 charged off to warranty.
So that should be what they would charge to change one.
Was a Pair-a-Sols!
Devoking is offline
post #4 of 5 (permalink) Old 05-25-2019, 06:49 AM
Location: Phoenix Arizona where there are about 250 days a year for convertible Bebop-ing
You can do it yourself, but before you do that siphon out about half a cup of the 90 weight and top it off with that motor stop leak stuff and wait about a month. It has chemicals in it to "fluff up" the seals. It worked for me with a '64 Impala convertible. If not it's a messy job but you can do it. It's a 'gomer' repair and I have never tried it on a Pontiac Solstice! Be carefull and read up on how to properly Lift the vehicle !!! Good Luck!
Bebop2 is offline
post #5 of 5 (permalink) Old 05-25-2019, 09:46 AM
if you decide to change it or if the axle has been out there are some special seal protectors that should be used so the splines on the axle shafts do not cut the seal as they are sharp,some jagged and love eating soft stuff. ebay has them for around $10. eazy to use and a must to use. I wish I had a spare diff to swap into my car so I could rebuild/check out the one it has. dam these are kinda pricey...then theres the shipping.....hell a dead one would be good I could change the gears and what ever else it needs...
marksbug is offline
Similar Threads
Hi, Differential Problem, I Apologize, I dont Have Time Read ALL Differential Topics Solskillz General Tech, Platform Common Issues & Solutions 4 05-26-2007 09:08 AM
Interesting Differential Leak Development FarTooDeep General Tech, Platform Common Issues & Solutions 72 06-14-2006 03:52 PM
Differential Leak? Brad General Tech, Platform Common Issues & Solutions 5 04-20-2006 06:23 AM
New Differential Leak MomsSol General Tech, Platform Common Issues & Solutions 28 04-18-2006 08:21 PM
Differential Leak Discussion beginning 03/30/06 Gizmo General Tech, Platform Common Issues & Solutions 10 03-31-2006 05:44 PM
