Dripping muffler . . . what are my options ? - Page 2 - Pontiac Solstice Forum
 11Likes
post #16 of 34 (permalink) Old 04-07-2019, 07:47 PM
syjos's Avatar
If a weep hole is engineered into the muffler design for water mitigation, the hole would be located on the bottom surface. The location of the hole in the muffler pictured would not allow all the water to exit.
I'm not sure if a weep hole is required on a muffler. The heat inside should evaporate the water.
Any muffler engineers out there?
syjos is online now
post #17 of 34 (permalink) Old 04-08-2019, 07:32 AM
Sounds like it's supposed to be there.
For the GMPP exhaust for the 2.4L, Borla still has them in stock in their "closeout corner" section. Mine was even stamped as a GMPP part.
https://www.borla.com/products/solst..._17802058.html
(If that link goes away, you can also google "borla 17802058".) As of today, they're $249 plus shipping for the complete cat-back.
If it turns out to be a crack or rust or whatever, you could have a muffler shop or any competent welder fix it, probably for about $30-$50 based on my experience. YMMV.
That should bolt up to the GXP as well, but it's a single-exit exhaust.
post #18 of 34 (permalink) Old 04-08-2019, 07:58 AM
AKA SolWhat?
DaveOC's Avatar
GMPP also had one for the GXP which was dual outlet.
raygun likes this.
1st 1K - #741
DaveOC is offline
post #19 of 34 (permalink) Old 04-08-2019, 08:00 AM
The holes in my RL mufflers definitely appear to be intentional, very round and precisely located. I can't quite imagine two mufflers rusting that way or in exactly the same location.
My NA muffler is not quite as early as Dave's, but it is an early 2007, so newer than either of the RLs. Is the lack of a hole because of its age, or because the NA mufflers were not thought to need them?
We need someone with a 2008 or 2009 NA to look for the hole in their muffler.
Sting Ya likes this.
JohnWR is online now
post #20 of 34 (permalink) Old 04-08-2019, 10:22 AM
Normybaby's Avatar
Me too
I have a 2007 base, I noticed the same drip when I ran it a few times during the winter storage. It clears up as soon as everything warms up. I'm going to check it it out when I get home
Normybaby is offline
post #21 of 34 (permalink) Old 04-08-2019, 10:42 AM
Sting Ya's Avatar
So after reading the above posts I have to believe that the mufflers were probably made by different suppliers that would seem to be why some have obvious weep holes and others don't ,I wouldn't plug it up it's there for a reason .Another example is that I purchased a GM performance exhaust system from my local dealer it and it was made by MagnaFlo and I've read that the GMPP exhaust was made by Borla so again two different manufactures .
Sting Ya is offline
post #22 of 34 (permalink) Old 04-08-2019, 12:12 PM
Originally Posted by Sting Ya View Post
So after reading the above posts I have to believe that the mufflers were probably made by different suppliers that would seem to be why some have obvious weep holes and others don't ,I wouldn't plug it up it's there for a reason ........
Possibly, but my experience with OEM suppliers is that we all work to the same drawings, so one or the other would be a non-conforming part.
The two scenarios I think are most likely are that:
1) The difference is between NA and RL/GXP with one design having the hole and the other not. Or,
2) A design change was made sometime in 2006 (possibly coincident with the introduction of the RL/GXP) so that all subsequent mufflers have the hole.
We need a larger and more varied group of samples.
post #23 of 34 (permalink) Old 04-09-2019, 03:35 AM
My car is 2.4 NA in 2007, and the exhaust is completely factory, there is a water drain hole.
Andreas72 is offline
post #24 of 34 (permalink) Old 04-09-2019, 11:02 AM
It seems pretty clear that the hole is a design change that was made some time in late 2006 or early 2007.
My 2.4 built in February 2006 doesn't have it and your 2.4 built in July 2007 does.
I suppose it could also be a manufacturing defect that it took 2 years to catch, but I rather doubt that.
post #25 of 34 (permalink) Old 04-09-2019, 11:44 AM
wspohn's Avatar
I checked the 2007 2.4 repair manual and could not find a reference to the wheephole, perhaps someone else is a better finder or maybe it is mentioned in repair manuals for other model years ?
But why would it ever be mentioned - it isn't like it is a service item.
The factory mufflers for the Kappas probably came from some Mexican factory and were made to GM specs. Lots of cars have mufflers with weep holes, it isn't at all unusual. Solstices seem to have been made both with and without. End of story. Doubt we'll ever be able to say much more about the subject.
phil1734 likes this.
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #26 of 34 (permalink) Old 04-09-2019, 01:18 PM
Originally Posted by wspohn View Post
..... Doubt we'll ever be able to say much more about the subject.
Of all of the things that you have posted that I have disagreed with, this might be the most extreme. This is a forum, and this is an item of trivia. We will always be able to say more about it.
post #27 of 34 (permalink) Old 04-09-2019, 01:22 PM
wspohn's Avatar
I guess that's true!
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #28 of 34 (permalink) Old 04-09-2019, 01:31 PM
phil1734's Avatar
...Solstices seem to have been made both with and without. End of story. Doubt we'll ever be able to say much more about the subject.
Just wait until you try to sell yours at Barrett-Jackson in a few years and you don't have the factory muffler weep hole!
2007 Solstice GXP
#3 ASP, DET and NWOR SCCA
phil1734 is online now
post #29 of 34 (permalink) Old 04-09-2019, 02:26 PM
wmf246's Avatar
yep, like the C2 corvette hood surround 'dimple' in the upper driver's side ledge....
Bill
wmf246 is offline
post #30 of 34 (permalink) Old 04-09-2019, 02:53 PM
Except that if it ever came to that someone would know which VINs should have it and which shouldn't, so you also want to be sure that you didn't have a hole that wasn't supposed to be there..
Similar Threads
2003 Chevy Astro water dripping under the sliding door. SKY_RL_Qc Other Car Discussion 0 08-08-2014 06:31 AM
Water Dripping from firewall bulkhead Solstice837 General Tech, Platform Common Issues & Solutions 5 10-06-2010 07:57 AM
Tears for Pontiac..... big dripping tears..... Dan Furr General Solstice Discussion 3 06-08-2009 06:24 PM
A/C Condensation Dripping onto Hot 'Parts' Solcycle General Tech, Platform Common Issues & Solutions 4 09-18-2006 09:03 AM
Muffler options bowhunter1331 Mods - Engine 2.4 l Ecotec 10 06-06-2006 07:52 PM
