Evap Canister unavailable? - Page 2 - Pontiac Solstice Forum
 3Likes
post #16 of 26 (permalink) Old 04-04-2017, 05:24 PM Thread Starter
Cool. Thanks for the picture. That is definitely the valve and canister
post #17 of 26 (permalink) Old 04-05-2017, 05:15 AM Thread Starter
Here are some pictures of the alternative evap canister. Its the HHR part which is basically identical with the Kappa part with the addition of one tab, a slid on metal cap and the relocation of the solenoid valve retention clip. It will be very easy to modify the HHR part to substitute for the Kappa part. The HHR part is the one on the right with the white hose fitting.
ID:	67529   Click image for larger version
ID:	67537   Click image for larger version
post #18 of 26 (permalink) Old 04-07-2017, 06:57 AM Thread Starter
I successfully modified the HHR canister to be a fit for the Kappa unit. I removed the metal top with a screwdriver. Then I used the band saw to remove one side tab and the large tab on the end.
Then I test fit the evap solenoid valve to both units. It fits fine in both cases. The difference with the HHR canister is the retention clip requires the solenoid to be rotated 90 degrees but it looks to me that it will still fit the Kappa just fine. If there is a fit problem it will be easy to mount the valve without rotating it and holding it in place with alternative means.
As far as I am concerned this is no longer an issue.
ID:	67617   Click image for larger version
ID:	67625   Click image for larger version
ID:	67633   Click image for larger version
HotScott likes this.
post #19 of 26 (permalink) Old 04-14-2017, 07:53 AM
Thanks for the details and pictures, Rob. I'm about to replace mine. This helps, a LOT.
rob the elder likes this.
post #20 of 26 (permalink) Old 04-14-2017, 09:57 AM Thread Starter
Glad to help
We have several cars in our club needing attention too
post #21 of 26 (permalink) Old 12-28-2017, 03:01 PM
prattm's Avatar
Send a message via Yahoo to prattm
Is the EVAP canister the same on both Turbo and NA?
If not, can someone give me the part number for the NA?
If I can't get a new canister, can the charcoal be replaced in the one I have?
Thanks in advance!
Sly, black leather, black top, 145 NA, loaded. Seems like it has everything but On-Star.
Mods:
Stuby Antenna, 42U Splash Guards, Painted Brake Calipers and Rotors
2007 bought new 5/16/08.
Loving every minute...
My other Toy:
1935 Auburn 851 Cabriolet
prattm is offline
post #22 of 26 (permalink) Old 12-28-2017, 04:09 PM
@RobTheElder posted a write up on modifying the HHR canister, basically trimming some tabs with a Dremel if I remember correctly. Original part should be the same for NA and turbo.
Technically, you can replace the charcoal, but getting the canister resealed may be a chore. *shrug*
post #23 of 26 (permalink) Old 12-28-2017, 08:18 PM
Thanks in advance!
Did you actually read through this thread? See post #4.
Yes. About 5 post up^ on this page
raygun likes this.
post #24 of 26 (permalink) Old 12-29-2017, 03:34 PM
wspohn's Avatar
I may be wrong, but I thought the manufacturers had to service emissions parts for a minimum time (I thought it was 10 years). Isn't this such a part and am I correct about their requirement to provide replacements?
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #25 of 26 (permalink) Old 12-31-2017, 09:11 AM
ChopTop's Avatar
VAPOR CANISTER (GM 15250111)
THIS PART FITS
Pontiac Solstice
2009 Base, GXP 2.0L L4 - Gas, 2.4L L4 - Gas
2008 Base, GXP 2.0L L4 - Gas, 2.4L L4 - Gas
2007 Base, GXP 2.0L L4 - Gas, 2.4L L4 - Gas
2006 Base 2.4L L4 - Gas
Saturn Sky
2010 Base, Red Line 2.0L L4 - Gas, 2.4L L4 - Gas
2009 Base, Red Line 2.0L L4 - Gas, 2.4L L4 - Gas
2008 Base, Red Line 2.0L L4 - Gas, 2.4L L4 - Gas
2007 Base, Red Line 2.0L L4 - Gas, 2.4L L4 - Gas
ChopTop is offline
post #26 of 26 (permalink) Old 12-31-2017, 07:39 PM
4501 Safari's Avatar
Arrow
Start the dance again? Price lowered $5.00 since I bought mine. It lives in its OEM box, with the FSM set sitting on it, under my computer desk here in the home office. Obviously I am not out celebrating New Year's Eve so let's simply wish for logic, reason and perhaps a little common sense and compassion. Oh hell, throw in ability and wisdom just to make 2018 interesting. Happy New Year!
Amazon: https://www.amazon.com/ACDelco-215-5...ype=automotive
ACDelco
ACDelco 215-582
GM Original Equipment Vapor Canister without Vent Valve Solenoid
5.0 out of 5 stars 1 customer review
Price: $74.59 Free Shipping for Prime Members
Richard Snipes
4501 Safari is offline
