Finally Fixed My Cup Holder - Page 7 - Pontiac Solstice Forum
 21Likes
post #91 of 101 (permalink) Old 01-27-2018, 12:45 PM
Originally Posted by Riven02 View Post
I have received a few people asking how to replace this part. So I figured I would just post a quick video showing the steps.
https://youtu.be/YAyV7TRZIpU
Those that posted this in other groups/forums, feel free to link to this video as well or if you want you could also send me a link and I will post it there.
Didn't know there was a video on it. Just installed mine and all I had to do was put the pins in and give it a little twist to get it into the tracks. It fits great but i can see why you put a little lube on there. Thanks for these.
Zeph94 is offline
post #92 of 101 (permalink) Old 01-30-2018, 09:06 PM
Interested in a couple cup holders. If possible send me the address and cost and I will put money in mail asap.
Mine is a 2006 base model. Hopefully with the increased technology some will make tuli panels.
Thanks
Gary
Cm005878 is offline
post #93 of 101 (permalink) Old 02-12-2018, 05:44 PM
Junior Member
Sure could use one in black if you'll sell me one.
johnobrien is offline
post #94 of 101 (permalink) Old 07-22-2018, 02:52 PM
Argh! Thingiverse is showing a 404 page for the cupholder link.
post #95 of 101 (permalink) Old 06-30-2019, 04:29 PM
WindySol's Avatar
Originally Posted by 44thSKY View Post
Here is an idea for a design.
And, we have one from the past. Can't seem to find them in the auto stores. Must be too far back in time. My wife likes hers, but we could use three more (two Kappas). (when it takes off, you will need a warehouse for a production facility, I applied for a patent, LOL)
Simple device, .... no batteries, no tools to install, might ship for a little more than regular postage, if instructions are needed, ask them to send it back.
This item is on Thingverse so anyone can print it
Hello Rob. Are you still able to print these? What about the part that the replacement arm goes into? Any luck printing those? Thanks
WindySol is offline
post #96 of 101 (permalink) Old 07-01-2019, 05:10 AM
When he started selling papers, he removed the files
post #97 of 101 (permalink) Old 08-03-2019, 09:42 AM
joybill44's Avatar
Here is a little trick I used with my Santana cup holder. It seems that in the solstice, the Santana doesn't hold a large cup very well due to the straight vertical surface it is mounted in. I built a standoff of 1/4" black ABS that makes the large cups fit much better. Pics are pretty much self explanatory.
ID:	98689   Click image for larger version
ID:	98691   Click image for larger version
joybill44 is offline
post #98 of 101 (permalink) Old 08-11-2019, 12:11 PM
joybill44's Avatar
a cup holder that works!
replaced my cup holder with the Santana holder after constantly tinkering with the OEM holder to keep it working. The Santana is a big improvement but needed some tweaking in order to hold a large cup as well as a can or small cup. I took out the center portion that rotates down to hold the bottom of the cup and made a new one with a piece of 1/4" aluminum sheet. now the small cans as well as large cups stand upright as they should. A little fancy work with a dremel tool on the back of the new piece enabled it to rotate upward as easily as the original.
ID:	98805   Click image for larger version
ID:	98807   Click image for larger version
ID:	98809   Click image for larger version
ID:	98811   Click image for larger version
RedOne07 likes this.
post #99 of 101 (permalink) Old 08-11-2019, 03:23 PM
Nice! You should've just made the whole thing yourself!
rob the elder likes this.
post #100 of 101 (permalink) Old 08-11-2019, 04:31 PM
I installed the Santana cup holder today. After I figured out that it needs to be mounted to the rear of the slot to clear the mechanism when it opens.
post #101 of 101 (permalink) Old 08-11-2019, 05:02 PM
joybill44's Avatar
wish I could have. would have saved me a boatload of money.
