IC and K04 Big Wheel install - Pontiac Solstice Forum
 1Likes
  • 1 Post By lorennerol
post #1 of 14 (permalink) Old 05-17-2019, 09:13 AM Thread Starter
I'm going to start this project today, with the IC. If time, I'll start the turbo this weekend.
For those of you who've done it...any tips, tricks, etc? Especially anything about the R&R on the turbo. The IC seems pretty straightforward- just have to reshape the mounting bars for the air dam. I have have the DDM charge tubes (not pictured). Upgraded clamps long since installed on the factory charge tubes.
Solo high flow cat and street race exhaust already installed.
TIA.
Name:	IMG_E2152 (Large).JPG
lorennerol is offline
post #2 of 14 (permalink) Old 05-17-2019, 01:53 PM
What are you planning on using the copper spray gasket for?
post #3 of 14 (permalink) Old 05-17-2019, 05:12 PM
-Raise the engine from the passenger side as high as possible!!!!
-Several nuts on my exhaust manifold where really loose, so don't forget to retorque the exhaust manifold nuts!!!
-Use plenty of wd40!!!
SSolstice is offline
post #4 of 14 (permalink) Old 05-17-2019, 05:18 PM
You are missing a wastage actuator rod retaining "clip", it's purpose is to prevent the nuts to become loose, but you can install the turbo and later on install the clip
post #5 of 14 (permalink) Old 05-17-2019, 07:01 PM Thread Starter
Thank you. It actually has nuts on a threaded rod instead of a clip in slots in a smooth rod.
Appreciate you for noticing and saying something.
post #6 of 14 (permalink) Old 05-18-2019, 06:25 AM
SolCal's Avatar
That clip was a production change. My early production GXP (#1,300ish) doesn't have one either.
SolCal is online now
post #7 of 14 (permalink) Old 05-18-2019, 05:47 PM
Make sure you don't have any metal shavings in that IC.
post #8 of 14 (permalink) Old 05-18-2019, 10:11 PM Thread Starter
Old out, new in today. Got stuck (it was 8:00 PM and I was tired anyway) installing new DDM polished charge tubes. They came with new silicone tubes that are thicker than stock and the t-bar clamps I installed years ago to replace the OEM clamps are too small.
I have a set of articulating, ratcheting box wrenches that make a couple steps easier (looking at you, bottom inboard down pipe nut). As does a pneumatic or electric ratchet. Oh, and a parking lift. Jeebus, I can't imagine doing the underside work laying on my back. Kudos to those who have.
Oh, and the turbo that was on the car (built July 2007 as a 2008) has the same nuts as the one I put on, not a retaining clip.
Tomorrow I hope to find bigger clamps and finish up the charge tubes, get the front end back on the car, and refill the coolant. Any tips on that greatly appreciated- it looks to be a PITA without the special tools, which I'd be willing to buy if I can find.
post #9 of 14 (permalink) Old 05-19-2019, 09:44 PM
who's tuning your car?
post #10 of 14 (permalink) Old 05-19-2019, 10:50 PM Thread Starter
Dave at Werks. I decided that would be best since the turbo and IC came from his shop.
I'll have some more photos on Tuesday after I get the M10-1 tap I need for the charge tube, the clamps, and the vacuum tool for refilling the coolant.
post #11 of 14 (permalink) Old 05-25-2019, 10:32 AM Thread Starter
Final fasten-down day, then load the first version of the new tune from Werks and off for a test drive.
Feels like Christmas morning!
raygun likes this.
post #12 of 14 (permalink) Old 05-25-2019, 11:05 AM
Saveaux's Avatar
Great job on the install, I hope the test drive goes smoothly!
Saveaux is offline
post #13 of 14 (permalink) Old 05-25-2019, 02:46 PM Thread Starter
Thank you. I hope I learned some things because we're doing my buddy's tomorrow
Only problem with the test drive is that a very light mist turned into rain and I had to cut it short. Not before I spun the wheels below WOT and saw it boost to 25, though. Tomorrow and Monday should be better for collecting some logs for Werks to chew on for v2 of the tune.
post #14 of 14 (permalink) Old 05-25-2019, 09:44 PM Thread Starter
Mechanically complete and test drive #2 in the books. It's running great. Can't wait for drier roads Sunday and Monday.
Name:	IMG_2236 (Medium).JPG
Similar Threads
Less than 100Mile Big Wheel K04 Turbo for sale. Mr. E Us Solstices and Parts for Sale/Want to Buy (incl other vehicles) 1 05-03-2019 12:25 AM
K04 "Big Wheel" upgrade experience/result? lorennerol General Solstice Discussion 30 03-09-2019 02:32 PM
FS: Stock parts: IC, driver's side pillar, backbone, IC grill, rear bumper part sky888 Solstices and Parts for Sale/Want to Buy (incl other vehicles) 7 05-22-2011 08:38 AM
Okay, BIG, big, big mistake... [broken antenna screw] Clemsonjoe Mods - Audio & Etc. 71 02-05-2006 01:21 PM
