New turbo - Pontiac Solstice Forum
 6Likes
post #1 of 23 (permalink) Old 07-09-2018, 02:27 PM Thread Starter
New turbo
Installing larger turbo today (RPM-K04 upgraded turbo charger).will drive tuesday for about 50 miles or more than start programming over next few days.
raygun likes this.
bigzee is offline
post #2 of 23 (permalink) Old 07-09-2018, 03:25 PM
What's your goal? More boost (which you can do with $10 of parts from O'NapaZone), reduced lag, just more hp / tq? Did you install new injectors (and associated tune)?
post #3 of 23 (permalink) Old 07-09-2018, 04:27 PM
Saveaux's Avatar
What is this $10 method of getting moar boost? Wastegate adjustment?
Saveaux is online now
post #4 of 23 (permalink) Old 07-09-2018, 07:25 PM
DO NOT drive a car with a new turbo and no tune for it!!!!!! The computer won't know you have a bigger turbo and I can guarantee with almost 100% certainty, you're going to pop your motor on a 50+ mile drive.
post #5 of 23 (permalink) Old 07-09-2018, 08:23 PM
shabby's Avatar
He'll be fine, its a minor upgrade. The ecm still knows how much air is passing through the maf so it will lower the boost to say 12psi at full throttle to achieve similar power of the stock turbo at say 15psi.
Sting Ya and raygun like this.
2008 solstice gxp - Solo Performance 3" mach exhaust + hiflow cat - dyno sheet
shabby is offline
post #6 of 23 (permalink) Old 07-10-2018, 07:12 AM Thread Starter
Just to put things in order so some of you dont go off in the wrong directions,I drag race the car on 1/8 mile strips which are the most abundant in Virginia area,1/4 mile are few and farther away.
My gxp ,automatic and 24000 miles already has trifecta tune of which Im changing,solocat,lnf tubes intercooler,back bone brace,pilot tires and runs only sunoco 93 oct.
With the new turbo I SHOULD GAIN 30-50 WHP AND 38LBS of air flow,which should add up yo 358whp and 386 lbs of torq.
I will be adding stage 3 tune by rpm motor sports after breaking in new turbo.
bigzee is offline
post #7 of 23 (permalink) Old 07-10-2018, 08:48 AM
On many cars, you can put a restrictor inline with the reference line to the wastegate. Makes it see less boost. The MAP will still show the correct boost level in the intake, but the wastegate won't open as early. On my 300ZXTT, we used welding gas nozzles inserted directly into the vacuum line.
On the GXP, it might take some work to do that, and you'd need a tune to disable the silly "learn down."
Or, add a momentary, normally-closed switch inline with the ECM fuses, so you can easily reset the damn thing periodically. (Hack for the day. You're welcome.)
post #8 of 23 (permalink) Old 07-10-2018, 12:25 PM
wspohn's Avatar
He should be OK if he babys it and avoids significant throttle openings before it gets tuned. But you are right, you can see huge amounts of antiknock activity from an untuned modded turbo, so all you need is a couple of missed signals to get engine damage.
Personally, I would recommend the whole trip with absolutely zero boost used.
Sting Ya likes this.
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #9 of 23 (permalink) Old 07-10-2018, 12:31 PM
@wspohn I agree. My primary concern would be exceeding the capacity of the injectors; but, again, that really depends on how much boost we're talking about.
I'd just baby it until the tune is dialed in.
post #10 of 23 (permalink) Old 07-10-2018, 12:38 PM
wspohn's Avatar
You don't have to worry about injectors on an LNF engine until you exceed 400 bhp by a decent amount. You are talking about the LNF, aren't you?
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #11 of 23 (permalink) Old 07-10-2018, 03:57 PM
He said a RPM-K04 which I am assuming is a large wheel upgrade to the OEM K04, so is about 350-360 BHP, this is based on my DDM tune with my K04 large wheel.
LatinVenom is offline
post #12 of 23 (permalink) Old 07-10-2018, 04:16 PM
Sure, but HP to boost is a correlation, not some sort of magical causal formula. Fuel capacity to boost is a requirement. Too lean, pistons go "pop."
You can't just say "turbo x" makes "hp y" so "injector z" is fine. I can overboost my 2.4 out the wazoo and happily blow a motor, with the recommended injectors. (Ask me how I know.)
AFR is key here.
You can happily make really terrible whp with a massive charge and insufficient fuel. It can go sideways very, very fast.
post #13 of 23 (permalink) Old 07-10-2018, 04:22 PM
Sure but he does not list any larger injectors, e85, etc, and is claiming 428 BHP out of a large wheel turbo.
post #14 of 23 (permalink) Old 07-11-2018, 06:31 AM Thread Starter
Morning took car home last night and put 60 miles on it at normal speeds not exceeding 60 mph as suggested by scott at rpm motors.
Next to take trifecta tune out and put to stock,drive and down load info to start new program.Didnt have any engine knock as the trifecta tune was still in the car
raygun likes this.
bigzee is offline
post #15 of 23 (permalink) Old 07-11-2018, 08:40 AM
wspohn's Avatar
Uh - why not just get the tune revised by Trifecta? Worked perfectly for me when I went to the same turbo you are using. A few logged pulls, send them back to Trifecta and get a personalized tune back that works.
BTW, I think that the modded big wheel K04 tops out it's envelope around 315 whp or 375-380 bhp and no increased fuel over stock injectors is needed. Unless you have even larger than normal wheels than the normal modded K04...
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
