Odd Occurrence at the Gas Station - Pontiac Solstice Forum
 2Likes
  • 1 Post By raygun
  • 1 Post By ChopTop
post #1 of 14 (permalink) Old 03-24-2019, 03:11 PM Thread Starter
The Silver Fox's Avatar
Mostly sunny 72 degree beautiful spring day so I took the Solstice out for some exercise. The low fuel warning light came on so I pulled in to the local Marathon gas station. Asked for a fill-up on pump #1 and gave 'em my credit card. Went to pump gas and the pump shut off almost immediately. Tried again with the same result. Couldn't put any gas into the tank. Went back inside and told the clerk that the low fuel light was on but it wouldn't take any gas. I managed to get $1.14 worth of gas into it. The clerk said they had the same problem with their KIA and it turned out to be a false alarm triggered by a faulty gas cap. He said to take it down to Autozone and they'd diagnose the problem for me. Autozone was 20 miles away and home was 5 1/2 miles. I went home. I had two five gallon gas cans on the front porch that were just filled up for use in my lawn tractor. I got my big funnel and a five gallon can and proceeded to pour all five gallons into my car ... the low fuel light went out.
Obviously the Solstice just didn't like the Marathon pump handle. Has anyone else had a similar experience?
The Silver Fox is offline
post #2 of 14 (permalink) Old 03-24-2019, 03:39 PM
Evap crap / charcoal canister.
If that isn't working correctly, the pump shuts off because it thinks that your tank is full. (Vapor feeds back up the filler neck.) Your hand-held cans don't care. There are a bunch of other threads here about that. It can be a PITA to fix depending on which component is failing.
(But, first try a different gas station. It could have been the pump!)
sirwm likes this.
post #3 of 14 (permalink) Old 03-24-2019, 04:43 PM
The most common cause of the charcoal canister getting clogged is supposed to be topping-up the tank when filling, because that dumps liquid gasoline into the canister. There is also a solenoid valve that is supposed to open when the engine is shut off, and there have been reports of charcoal getting out of the canister and blocking the fuel line.
A guy on the Sky forum just had one replaced by his dealer for $2,000.
The official repair process involves removing the tank to get to it, but a way that takes rather less labor is to remove the trunk liner and cut the top off of the "mayan temple" to access it from the top.
The problem can be intermittent and raygun is correct that some pumps can be over-sensitive to backpressure.
post #4 of 14 (permalink) Old 03-24-2019, 05:18 PM
ChopTop's Avatar
Did you try repositioning the pump handle? I've had the pump stop a few times on several different cars when putting gas in. I then remove the pump handle and repositioning it. So far that method fixes the problem.
easyryderca likes this.
ChopTop is offline
post #5 of 14 (permalink) Old 03-24-2019, 06:16 PM
There is a thread with pics of the replacement.
Check the vent solenoid valve. It may have an issue
post #6 of 14 (permalink) Old 03-24-2019, 08:45 PM
al_c's Avatar
The first time I gassed up after buying my Sol, I encountered the same thing. Never again since, though. I guess some pump handles are just finicky.
al_c
al_c is online now
post #7 of 14 (permalink) Old 03-25-2019, 07:00 AM
https://www.solsticeforum.com/forum/f...2/#post1996729
Pics of the tank
post #8 of 14 (permalink) Old 03-25-2019, 07:41 AM
showtime's Avatar
I had a similar problem with a boat and it turned out to be a spider web in the vent.
showtime is offline
post #9 of 14 (permalink) Old 03-25-2019, 10:21 AM
I have that problem with every car I own. All that happens is...If I put the pump all the way into the tank and squeeze the pump to fill on it's highest amount it will click off. I pull the pump nozzle out some then put it on half quickest and can fill both my Saturn and Jag up to full no problem.
MattM is offline
post #10 of 14 (permalink) Old 03-25-2019, 04:18 PM
WintR's Avatar
I recall that a Japanese brand car had a spider problem a few years back, too. I just can't recall the brand.
Mods: Kappasphere CAI, Clear Image Shorty Header, second horn, visor decals, mudflaps, tonneau cover, brake light flasher, trailer hitch, 'lil Chromies, trunk monkey, retune, DDMWorks backbone, GMPP Suspension, wood grain dash, Solo Quiet cat-back exhaust, deleted:Solo high-flow cat
WintR is offline
post #11 of 14 (permalink) Old 03-26-2019, 08:19 AM
al_c's Avatar
Mazda 6. Mine was part of that recall.
al_c
al_c is online now
post #12 of 14 (permalink) Old 03-28-2019, 05:06 PM
MEANGXP's Avatar
All valid possibilities for premature shut off.
But try a different pump before worrying much about any thing else.
Our durability test fleets logged thousands of fuelings yearly, and there are a ton of bad pump handles in use everywhere out there.
'07 GXP - 3/10/2007 - Mean - 5 Speed Manual - Black Leather w/gray stitching -
Spoiler - Monsoon - XM - A/C - Chrome wheels - Sport pedals - Headliner - BSR Tune - Solo Mach Shorty
'YOU DON'T NEED A TRUNK TO HAUL ASS'
MEANGXP is offline
post #13 of 14 (permalink) Old 03-29-2019, 05:24 PM Thread Starter
Follow up:
Went to the local truck stop today and filled up with no issues.
post #14 of 14 (permalink) Old 03-29-2019, 08:43 PM
Saveaux's Avatar
Originally Posted by The Silver Fox View Post
Follow up:
Glad to hear it!
Saveaux is online now
Similar Threads
What Gas Station Sells Best Quality For Solstice? Solskillz General Solstice Discussion 23 05-25-2007 04:50 PM
Indy radio station giving away a Solstice simmonsmb Great Lakes 0 03-06-2006 10:17 AM
N.J. Stepping Up Gas Station Inspections As Pump Prices Rise solli4me General Off Topic 2 09-02-2005 11:10 AM
So I had an interesting experience at the gas station yesterday... Clemsonjoe General Off Topic 37 08-17-2005 09:43 AM
