Put a ding in my car closing the trunk! [Don't close trunk pushing on humps] - Page 2 - Pontiac Solstice Forum
post #16 of 69 (permalink) Old 02-10-2008, 09:48 AM
kd4z's Avatar
Originally Posted by Charley View Post
You're right. I've had to deal with that too.
I do that, but it's like I get air pressure at the last six inches. Strange, since there are huge drain holes in the trunk! This car has a very elaborate gutter system.
I was shown a trick by jrsno1fan that really works if you are in the "closing from the side" crowd. Works when closing with top down. Before closing the trunk lid, with your right hand (at your preferred location), take your left hand and open the springed flap in the silver stripe area. Make sure your left hand is clear of the trunk lid and then close the trunk lid with your right hand. The opening due to the little flap opening lets the air out of the trunk as the lid closes, requiring a lot less force! Thanks jrsno1fan
kd4z is offline
post #17 of 69 (permalink) Old 02-10-2008, 10:42 AM
I think whatever method you use, the key is to have your hand off the lid by the time it slams shut. The dent comes from your hand still being there and banging down on the lid when it comes to a sudden stop.
Mike
mikeysolstice is offline
post #18 of 69 (permalink) Old 02-10-2008, 08:44 PM
did same thing to my hump
it helps if you close it with your fingers on the side
AutobotJazz is offline
post #19 of 69 (permalink) Old 06-05-2008, 10:32 AM
prattm's Avatar
Send a message via Yahoo to prattm
I tried this method yesterday, this is the best so far!
Went down easy every try.
Thanks
kd4z
prattm is offline
post #20 of 69 (permalink) Old 06-05-2008, 10:51 AM
Excelsior's Avatar
Use the latch hook on the trunk lid itself! grab with finger, swing down with force, let go, it slams shut. No fingerprints, no dents forever! I should make a video and have it stickied.
Previous #14 Owner - "Bumble" / Previous(crashed) 08 GXP - "Bruiser"
CNY Kappa Club Event Calendar 2011
° KAPPA REGISTRY °
* attendee: 2010 NASSM | SMMM8 *
Excelsior is offline
post #21 of 69 (permalink) Old 06-05-2008, 12:29 PM
Deepbluegxp's Avatar
The engineers at the plant tour said to close it by pressing down on the hump above the front edge bracket. I've been doing that for over a year with not issues. He said not to close it via the buttress chrome piece because over time you will cause that edge to start bending down.
For those of you that close it that way, look at the alignment of both sides before you push down the buttress into the chrome and you will see that one side is lower than the other.
See my car on cardomain.com
Deepbluegxp is offline
post #22 of 69 (permalink) Old 06-05-2008, 12:39 PM
mceb's Avatar
Hey deepbluegxp, can you explain better what when you say "the hump above the front edge bracket"? I've been doing the chrome buttress pin method and would like to learn the way you described, thanks.
Pontiac RIP 1926-2009
mceb is offline
post #23 of 69 (permalink) Old 06-05-2008, 12:42 PM
jeff_b_wilson's Avatar
To take a different bend on this thread (pun intended), when I got my car back from the dealership after they replaced the top I was attempting to close the trunk and it just kept bouncing up. After several attempts (not very smart ) I finally noticed that a rubber bumper on the underside of trunk lid (there is one on each side of the lid) that apparently helps position the top in the trunk, had fallen off into the drain channels and was keeping the lid from shutting all of the way. Of course my efforts to close it forcefully resulted in a slightly warped trunk lid (larger gap on the passenger side rear lights than on the driver's side). I glued the rubber piece back on with gorilla glue but just recent had to reglue it. It is easy to bump off if working in the trunk.
Regards,
Bodean
(North TX, 2007 "Cool" GXP Automatic with Escort 9500ic, Custom Wind Restrictor, K&N air filter, Hahn BSR Tune & Hahn IC, Flash2Pass, MagnaFlow muffler, Alpine PDX-5 amp with Pioneer Components & Sony Xplode Sub, DDM ProBeam & Backbone Brace, Werks front frame brace, Solo Hi-Flow CAT, Halo Demon Eyes), Hide-Away plates, Cherry dashboard, GM Roadster Hi/Lo HID's and Fog lights, Variable Sprint Booster, LED Tail Lights/3rd Brake Light, WR Lighted Door Sills
jeff_b_wilson is offline
post #24 of 69 (permalink) Old 06-05-2008, 01:05 PM
With the trunk open, you can see the front brace I have an arrow pointing to. Above that brace 1 inch back on the humps is where you should be pushing to close the trunk.
post #25 of 69 (permalink) Old 06-05-2008, 01:12 PM
Lenny's Avatar
Originally Posted by dave clancy View Post
thats how I close mine too
Same here
Lenny
2007 N/A Aggressive. LSD, AC, ABS, Auto, Premium package. Delivered 04/23/2007
In a truly free country, Alcohol, Tobacco and Firearms would be the name of a convenience store, not a federal agency.
Lenny is offline
post #26 of 69 (permalink) Old 06-06-2008, 07:53 AM
mceb's Avatar
Thanks deepblue, I'll have a look at that
mceb is offline
post #27 of 69 (permalink) Old 05-25-2009, 09:45 AM
DragonSolGXP's Avatar
So, the dealership teaches me to close the trunk from the center and to the front - ultratight when brand-new.
I forgot and slammed it from one side, using the driver's side nacelle (the Mayan Temple) and my palm put a ding in the darned thing! My car is Mean yellow, so it really shows up.
I wish that sucker was carbon fiber, so it would be dingproof. That really bummed me out! I love the Sol's light weight, but I've got cans from Libby's that are thicker than the skin on my Sol!
Haha! But you can't pry me out of this car.... Fun, fun, fun!
Hi Charley,
I know it's been a while, but I have the exact same problem (and color). Did you get it worked out at a Paintless dent removal place? How does it look? Thanks
DragonSolGXP is offline
post #28 of 69 (permalink) Old 05-25-2009, 10:15 AM
Sol-Lee's Avatar
Hey guys, I did the same thing on my 'hump' last year! Went to a paintless dent guy who worked miracles, it totally disappeared! Since then I close mine from the very center where the latch is and making sure not to still be pushing when it makes contact with the latch. The method with opening the small trap door to allow air out is an excellent idea!
Actually the very best fool proof way that I practice now, never even look at the top, its stored and never comes out, problem solved! lol....
Sol-Lee is offline
post #29 of 69 (permalink) Old 05-25-2009, 10:51 AM
Darkwing's Avatar
Originally Posted by Aspenrose View Post
I've never closed mine with a hand pushing down anywhere-get within 12" or so from closing and give it a fling-have it by the protected area under the buttresses and let 'er fly. Closes every time. (Just remember to let go on the down swing )
Aspenrose....soon to be known as Ninefingerrose.
Darkwing is offline
post #30 of 69 (permalink) Old 05-25-2009, 03:16 PM
JeffInDFW's Avatar
My car was delivered with a dent on the hump from closing the lid by the make ready guys. They had their paintless dent removal guy attack it, and you absolutely can not find it anymore. Amazing, really.
My Solstice trunk closed easily, but my Skys is a BEAR. You have to **SLAM** it. That is, until a forum member told me to try the "lift the silver flap" method mentioned earlier in this thread. I'll be dang. That solved it. It now shuts SOOOOO much easier.
JeffInDFW is offline
