Radio clock light - Pontiac Solstice Forum
post #1 of 3 (permalink) Old 08-04-2019, 11:40 AM Thread Starter
Junior Member
Radio clock light
My radio clock light is dim when the car is running but when I shut the car off the light brightens up. I have the dash light dial turned up to max. Is this normal or is there something I can do to fix it.
berwickrg is offline
post #2 of 3 (permalink) Old 08-04-2019, 02:40 PM
Sly Bob's Avatar
Are the headlights on? Something on the top of the dash blocking the light sensor?
Born April 30, 2008
Delivered on May 27, 2008
Sly Bob is offline
post #3 of 3 (permalink) Old 08-04-2019, 04:22 PM
Even when turned to maximum the radio and DIC displays are approximately 1/2 of the daytime brightness, so if the sensor turns the headlights and instrument lights on what you are seeing is normal.
You will also get them to full bright if you turn the auto-lights (and DRLs) to off by rotating the headlight control backwards. Rotating it backwards a second time will turn everything back to normal auto, as will cycling power to the car.
If this is happening in full midday sun, Bob's question about something blocking the sensor is a good one.
