Seatbelt Retractor - Pontiac Solstice Forum
 2Likes
  • 1 Post By grizhlr
  • 1 Post By TomatoSoup
post #1 of 3 (permalink) Old 04-15-2019, 08:19 AM Thread Starter
Seatbelt Retractor
I need to replace the drivers seatbelt retractor. I'm fairly new to working on the Solstice. Just bought it last fall and it looks like the pervious owner did a very poor job on maintenance. I have figured out that replacement parts are hard to come by. Wondering about removing the cover for the seatbelt. Does the cover for the seatbelt snap off, or is there a trick to get it removed. Don't want to break any tabs. Also are the retractors available or are they interchangeable with others? Thank for any help available.
MarkH likes this.
grizhlr is offline
post #2 of 3 (permalink) Old 04-15-2019, 08:50 AM
4501 Safari's Avatar
Arrow Try these folks...
I don't know if these folks can help but they have been in the business long enough to give you a good answer. I will have them reweb the driver side seat belt for my Roadmaster wagon in a month or two. They will work on a detractor IF it is capable of repair. Worth your time to contact and find out. You may have to send the part in for evaluation.
https://www.ssnake-oyl.com/ For the rest of us interested, with seat belt issues, take a look. I think you will be glad you did.
On tax day 2019.
Richard "I don't make enough money to NOT pay taxes!" Snipes
4501 Safari is offline
post #3 of 3 (permalink) Old 04-15-2019, 09:50 AM
Everything snaps off. You'll need to pull up the plastic sill plate first, then the 3/4 panel. Better to use plastic pry tools for the 3/4 panel, not just pull. Those panels are formed from an inner and outer piece and you can break the welds between the two if you just pull on the outer (unless you're very careful). Then you may need to (I can't recall for sure) lever back that side of the big 'waterfall' panel for full access to the retractor. Again, pulls off.
UPDATE: a couple of pics from google search:
http://www.cherod.com/solstice/HowTo...s/image011.jpg
MarkH likes this.
Similar Threads
Seat Belt Retractor Cpt_kludge General Solstice Discussion 2 06-10-2007 02:46 PM
Seatbelt Wet AA77 911 General Tech, Platform Common Issues & Solutions 6 11-27-2006 08:11 PM
Seatbelt/Airbag wrecked06 General Tech, Platform Common Issues & Solutions 19 10-31-2006 02:23 PM
If this doesn't make you want to wear a seatbelt... Axel General Off Topic 16 02-12-2006 03:21 PM
Seatbelt wet after rain Paul830 General Solstice Discussion 5 02-07-2006 05:48 AM
