Shifter pate - Pontiac Solstice Forum
 1Likes
post #1 of 17 (permalink) Old 04-13-2019, 03:00 PM Thread Starter
Shifter pate
anyone know where I could get one of the shifter plates with the shifter positions on it the chrome and the chrome ring that goes around it?
wallace is offline
post #2 of 17 (permalink) Old 04-13-2019, 05:47 PM
Are you asking about a gated shifter? As far as I know, no one has done one.
post #3 of 17 (permalink) Old 04-13-2019, 09:23 PM
Saveaux's Avatar
If your asking about an OEM replacement, then they pop up on eBay quite often; 2 have sold in the past week.
Saveaux is offline
post #4 of 17 (permalink) Old 04-14-2019, 06:55 AM
I think he means the auto shift plate
TomatoSoup is online now
post #5 of 17 (permalink) Old 04-14-2019, 08:46 AM
I looked at making a gated shifter plate but I don't think it's realistic. (Or, at least *I* couldn't figure it out.) The distance from the pivot to the area around the shifter is so small that there's not really enough room between the position of the shaft in different gears. The short shifter (which is awesome) exacerbates the issue.
Many of the cars I've seen that have OEM gated shifters have cable-driven shift mechanisms with a pivot that's much lower in the car, resulting in a lot more left-right movement of the shifter between gears.
It'd be great if someone has figured out a way around this, but I've got nothin'.
post #6 of 17 (permalink) Old 04-14-2019, 08:48 AM
chickenwire's Avatar
I thought he was looking for a liver appetizer type thing...
chickenwire is offline
post #7 of 17 (permalink) Old 04-14-2019, 08:55 AM
Could be. I don't tend to think in terms of "auto".
Another significant problem is having the shifter mounted to the transmission (which is a good thing except in this instance) and the gate mounted to the chassis, since the transmission can move relative to it.
I don't actually laugh out loud when reading things, but I did after this. Thank you!
raygun likes this.
post #8 of 17 (permalink) Old 04-14-2019, 08:59 AM
Be aware that a gated shifter plate will make shifting more "difficult' , but it looks cool though.
In the couple of cars I've driven with gated shifters - I'm specifically thinking of an F355 - you couldn't really hit the gate with the shifter. The key to its operation was just to not look at the shifter. As long as I kept that in mind, it shifted just like any other manual, though without a lot of the slop that you get in lower-end cars.
post #9 of 17 (permalink) Old 04-14-2019, 09:13 AM
If you are looking for the plate that is part or the automatic transmission shifter assembly:
FactoryOEM and SourceOne both have the assembly for a Sky, but neither has one for the Solstice.
Try Glenn: https://www.solsticeforum.com/forum/...7/#post2175957
post #10 of 17 (permalink) Old 04-14-2019, 11:20 AM
TireKicker's Avatar
You could make one by hand and get it etched up still look pretty good. Seems like the main purpose would be down shifting making super sure you didnt hit first while clipping pretty good
Name:	solstice concept dash.jpg
TireKicker is offline
post #11 of 17 (permalink) Old 04-15-2019, 07:24 PM
Saveaux's Avatar
Why are there two of these threads going?
Saveaux is offline
post #12 of 17 (permalink) Old 04-15-2019, 07:57 PM
The OP duplicated his post, and the two have drifted in different directions.
post #13 of 17 (permalink) Old 04-16-2019, 10:45 AM
ChopTop's Avatar
Maybe he's talking about the chrome plastic shifter surround:
ChopTop is online now
post #14 of 17 (permalink) Old 04-17-2019, 10:46 AM
If looking at the manual stock shifter, it can have a gated plate if it is inset way down in the tunnel.
yevgenievich is offline
post #15 of 17 (permalink) Old 04-18-2019, 05:44 PM
solactor's Avatar
Is that a photoshop or actually someone’s solstice ?
VIN# 4257 Deep - Conv. pkg-Power pkg - ABS - LSD - floormats Mods: Kappashield - Chrome door locks - caliper decals - visor sticker covers - Kappa alum pedals - Vector ECM reflash - AEM Cold Air Intake - Flowmaster 40 exhaust - chrome fender vents - aluminum door sills - RK sport rear wing (best appearance mod yet) Normís Recessed Grills- awesome!
solactor is offline
Similar Threads
Shifter pate wallace General Solstice Discussion 6 04-15-2019 04:36 PM
Lost Auto Shifter Retainer Clip when switching shifter.. O_O GeneralDodo General Solstice Discussion 11 09-30-2014 02:22 PM
Aftermarket shifter availability? vlevick Solstices and Parts for Sale/Want to Buy (incl other vehicles) 8 10-17-2005 02:19 PM
Shifter Slipstream General Solstice Discussion 8 08-16-2004 02:35 PM
Shifter gate Brian General Solstice Discussion 30 06-11-2004 11:59 AM
