Water pump holding tool -- brand? - Pontiac Solstice Forum
 2Likes
  • 2 Post By JohnWR
post #1 of 6 (permalink) Old 05-17-2019, 10:09 PM Thread Starter
jwvess00's Avatar
Hello,
When I pulled my '06 out of the shop this spring I noticed a bit of coolant under the right front of the car. Hrm, that's weird. It was a bit low, too, so I topped it off. I didn't see anything from the top that showed a leak. I serviced the cooling system in 2016 (coolant change, new thermostat, new hoses). My car has about 90k miles on it.
It's a bit low again and I think I saw a small puddle under the car again. I still haven't seen anything from the top. I'll get under it soon and see if I can see a drip, but I'm suspecting the water pump.
For the holding tool, does brand matter? It looks like OTC has one style (a full circle) and Lisle's tool is a half-circle. There's not much difference in price, so if I have to change it, I just want to get the best one for the job.
Thoughts?
Jay Vessels
jwvess00 is offline
post #2 of 6 (permalink) Old 05-17-2019, 10:13 PM
The full-circle tool has been recommended. It seems to make dropping one of the screws into the engine less likely.
ChopTop and joybill44 like this.
post #3 of 6 (permalink) Old 05-18-2019, 05:11 AM
SolCal's Avatar
You want the full circle tool, it does help prevent dropping a bolt into your engine. I know because I used the full circle tool. I'm clumsy and dropped a bolt when replacing mine, no big deal. There are threads here that start with "I dropped a bolt into the engine while changing my water pump". They all were using the half circle. It works, it's just riskier.
SolCal is online now
post #4 of 6 (permalink) Old 05-18-2019, 04:58 PM
Eliminate the worry of a dropped bolt by purchasing a set of metric magnetic nut drivers from Harbor Freight Tools. They are very inexpensive and make the job less stressful.
lacajun is offline
post #5 of 6 (permalink) Old 05-18-2019, 07:43 PM
joybill44's Avatar
full circle tool definitely.
joybill44 is offline
post #6 of 6 (permalink) Old 05-18-2019, 08:15 PM
Sly Bob's Avatar
I agree with others and I'd recommend the full circle tool.
Born April 30, 2008
Delivered on May 27, 2008
Sly Bob is offline
Similar Threads
Do I need water pump holding tool for 2009 solstice partinsm General Solstice Discussion 3 01-06-2018 08:24 AM
Water pump - Fuel pump question wildfiglane General Tech, Platform Common Issues & Solutions 10 01-19-2016 08:25 PM
FS water pump sprocket tool frmula505 Solstices and Parts for Sale/Want to Buy (incl other vehicles) 4 03-19-2013 06:37 PM
Does Water Pump Brand Matter? strikeouttruck General Solstice Discussion 6 04-04-2012 07:34 AM
Who's holding out for an automatic? FieroFan General Solstice Discussion 47 01-28-2006 11:52 PM
