Keyless entry - Pontiac Solstice Forum
 1Likes
post #1 of 28 (permalink) Old 09-06-2019, 05:43 PM Thread Starter
Keyless entry
So when I got my coupe it is clearly a replacement key and fob... looks like one of those generic ones you can get off eBay. The lock and unlock work well enough but it has a “trunk” button. It doesn’t do anything. Did the original have a trunk button that would pop the hatch glass?
Dox1974 is offline
post #2 of 28 (permalink) Old 09-06-2019, 06:57 PM
wmf246's Avatar
yes
Bill
wmf246 is offline
post #3 of 28 (permalink) Old 09-06-2019, 07:44 PM Thread Starter
So the fact mine doesn’t would you think that’s a programming issue with the fob or potentially something on the car?
Dox1974 is offline
post #4 of 28 (permalink) Old 09-07-2019, 08:27 AM
joybill44's Avatar
Originally Posted by Dox1974 View Post
So the fact mine doesnít would you think thatís a programming issue with the fob or potentially something on the car?
There was a common problem with the battery retainer clip coming loose at the soldered joint inside the fob. I would guess that since your fob does work for the doors, the problem is probably with the car.
Bill.
joybill44 is offline
post #5 of 28 (permalink) Old 09-07-2019, 10:16 AM
sirwm's Avatar
you have to determine if the glove box button pops the coupe back window.
If so, then the key fob is likely the issue.
If the glove box button does not pop the window, then there is a problem inside the car itself.
did you get only 1 key fob with the car ?
Sir William's Fleet
sirwm is offline
post #6 of 28 (permalink) Old 09-07-2019, 01:21 PM
The previous two posts are essentially correct:
Because the remote lock/unlock functions work:
1) If the release button in the glovebox works, the car is OK.
2) The car has been properly programmed to recognize the fob.
3) The most likely problem is the fob's trunk button.
You can open the fob to check and clean the button's contact pad.
JohnWR is online now
post #7 of 28 (permalink) Old 09-08-2019, 04:41 AM Thread Starter
Great info... thanks. The glove box button works fine so I’ll pull apart the fob and see if it looks like there is any problems. Unfortunately yes just the one set of keys for the car. I’d like to get another but I’m not sure what the process is. Does it have to go to a GM dealer to get programmed?
Dox1974 is offline
post #8 of 28 (permalink) Old 09-08-2019, 07:35 AM
The key is easy. You can get one cut just about anywhere, just make sure that the blank includes the Passkey chip. You can teach it to the car yourself using your existing key .
The fob is not quite as easy since it requires a separate programmer. Dormant sells one that is good for several reprogramming sessions or you can get it done by a dealer or anyone with a Tech2 or equivalent scanner.
Many of us have them, so you may be near someone who would do it for you.
post #9 of 28 (permalink) Old 09-08-2019, 08:57 AM
joybill44's Avatar
If you get really lucky, sometimes just cleaning off the rubber buttons and the contact points on the pc board will solve the problem.
Bill.
post #10 of 28 (permalink) Old 09-08-2019, 12:35 PM
Unfortunately yes just the one set of keys for the car. Iíd like to get another but Iím not sure what the process is. Does it have to go to a GM dealer to get programmed?
You only need to go to the dealer (or buy a programmer) for the remote fob. Additional keys you can do yourself easily - as long as you have at least one working key. Just get a GM-compatible key blank from a hardware store (or Home depot, etc) and get it cut to match your existing key. Then there are simple programming steps to program the anti-theft chip that can be found in your owners manual. (or: https://www.solsticeforum.com/forum/...43/#post832194)
post #11 of 28 (permalink) Old 09-09-2019, 09:11 AM
easyryderca's Avatar
Finally had an extra key made just to open the car as i have locked myself out twice in the last two years. Is this old age?
easyryderca is offline
post #12 of 28 (permalink) Old 09-09-2019, 09:36 AM
I guess that depends on how it happened and what you consider "old". Where do you keep the extra key?
post #13 of 28 (permalink) Old 09-09-2019, 02:09 PM
SolCoupe171's Avatar
You might want to check to see if the ignition recall was performed on your coupe. I was only given 1 key when I bought mine used (never did get a fob - my coupe must not have been set up with one when it was made or they were lost by the previous owners). After I had it about a month, the car died while I was driving it. Luckily I have a manual and was able to restart it while it was moving. I checked to see if the recall had been done and it wasn't. The dealer that did the recall work gave me 2 keys. They did ask if I had the additional original key, which I didn't and they still gave me two. If the recall was done you'll have to have one made, if not you should get two keys when the recall work is done. I'm not sure if they give two fobs, it's worth checking out.
SolCoupe171 is offline
post #14 of 28 (permalink) Old 09-09-2019, 02:57 PM
They will not give you any fobs. But I agree they will give you two keys even if you only have one (that's what I did - "lost" the other key).
post #15 of 28 (permalink) Old 09-09-2019, 04:15 PM
....... - my coupe must not have been set up with one when it was made or they were lost by the previous owners.......
Check the inside of your glove box door. If AU0 is one of the RPO codes listed you have Remote Keyless Entry.
'Soup is correct about not getting fobs and about getting two keys with the ignition switch recall.
