2.4L VVT ECOTEC Dyno Graph - Pontiac Solstice Forum
post #1 of 39 (permalink) Old 05-08-2005, 07:01 PM Thread Starter
Administrator
brentil's Avatar
Well, I've been chcking GM Dealer World every day in hopes of finding new info. There's a couple specific things I look for. Wheel images, radio images, engine info, etc.
Well this weekend GM officially put up the dyno graphs for the 2.4L VVT ECOTEC engine across all the lines using it except the HHR so far.
I've attached the following files;
  1. Solstice dyno graph
  2. G6 dyno graph
  3. Cobalt SS dyno graph
  4. Cobalt 2.2L dyno graph
  5. Cobalt SS Supercharged dyno graph
I'm working on photochop of them together for comparison reasons.
ID:	1330   Click image for larger version
ID:	1331   Click image for larger version
ID:	1332   Click image for larger version
ID:	1333   Click image for larger version
2006 Mysterious Solstice
2007 Mean Solstice GXP
2008 Velocity Yellow Corvette Coupe
brentil is offline
post #2 of 39 (permalink) Old 05-08-2005, 07:10 PM
psycho-squirrel's Avatar
Nice find brentil!
I am curious as to why the Solstice 2.4L has a hiccup around 3000 rpm for both torque and HP?
The torque curve at 3 grand has a dramatic dip, while the hp graph is only slightly affected.
There seems to be little or no hiccup on the other 2.4's (detuned versions).
Anyone have an idea about what's going on here?
psycho-squirrel is offline
post #3 of 39 (permalink) Old 05-08-2005, 07:16 PM
rlhammon's Avatar
Thanks for the post...
I only wish that the graphs had common scaling so that you could compare them side by side without a little more ease.
Seeing as the Cobalt is roughly 130 lbs. heavier, and little less torque, and it's front wheel drive I think the Solstice will be "fun" to drive, though a FI motor would be "more fun".
You can break loose the tires in the base Cobalt in 1st and the 1st to 2nd shift. I haven't had the pleasure of driving the Cobalt SS w/ the Supercharger in it tough, and doubt I'd be able to "test" it as I would like.
Glad to see the official dyno's though... great find, and thanks for looking (so I and others didn't have to).
rlhammon is offline
post #4 of 39 (permalink) Old 05-08-2005, 07:54 PM
Mod Emeritus
Great find Brentil! That is a funny hiccup. Cam changeover for the VVT?
Solstice and Sky Fan
Fformula88 is offline
post #5 of 39 (permalink) Old 05-08-2005, 08:09 PM
Originally Posted by Fformula88
......... Cam changeover for the VVT?
That's my guess.
DreamerDave is offline
post #6 of 39 (permalink) Old 05-08-2005, 10:54 PM Thread Starter
Administrator
brentil's Avatar
Combined comparison graph to scale.
I wanted to say VVT too, but look at the 2.2L, it has it too.
brentil is offline
post #7 of 39 (permalink) Old 05-08-2005, 11:12 PM
Could be tired/bad valve springs developing a harmonic. Do the ecotec springs use dampers or are they beehives like the LSx engines?
Stonebreaker
1996 Impala SS 11.99 @ 115 mph
PhD in RE (Redneck Engineering)
It works in practice, but does it work in theory?
stonebreaker is offline
post #8 of 39 (permalink) Old 05-09-2005, 04:01 AM
The LT1 has exactly the same "hiccup". I've seen it on other graphs, too. It's not uncommon. VVT? No, I don't think that's part of it.
WaitingForBoost is offline
post #9 of 39 (permalink) Old 05-09-2005, 04:43 AM
Hehe maybe Im being anal but the torque drops a few ft/lbs below 90% of peak at that dip at 3000....not that i care about a few ft/lbs really...its just the point
ImSlow is offline
post #10 of 39 (permalink) Old 05-09-2005, 07:03 AM
cdb
cdb's Avatar
it looks like the solstice motor is tuned to produce the most torque in the low rev range compared to the other NA ecotecs. that could accentuate the dip at the VVT changeover. if the trade is a dip at 3000 for more tourque off the line then i'm all for it.
cdb is offline
post #11 of 39 (permalink) Old 05-09-2005, 07:05 AM
Adrenaline's Avatar
From the other thread on shifting techniques and my recent discoveries, having a drop at 3,000rpm isn't a big deal at all, just shift a little before 3,000.
Adrenaline is offline
post #12 of 39 (permalink) Old 05-09-2005, 07:25 AM
OK, you guys that're better than me with a calculator, could you figure out if up shifting at 6500RPM would drop you above or below that torque valley around 3000RPM?
post #13 of 39 (permalink) Old 05-09-2005, 08:13 AM
I highly doubt it will drop even close to 3000rpm...anyone get transmission numbers yet? If it does Im gonna go buy something else .....in my current neon when i shift at 6500 from first to second gear it drops to roughly 4800
ImSlow is offline
post #14 of 39 (permalink) Old 05-09-2005, 08:29 AM
SkyCaptain's Avatar
1st, the fourth dyno pic is pretty screwed up. The lines are supposed to cross at 5252...
2nd, I'd definately have to drive the car to see if the flat torque makes up for the ridiculously low hp in the low rpm ranges...
Veritas Aequitas
And we shall flow a river forth to thee
And teeming with souls shall it ever be.
SkyCaptain is offline
post #15 of 39 (permalink) Old 05-09-2005, 09:11 AM
Administrator
SolsticeMan's Avatar
I thought the same exact thing, Sky'. For whatever reason, they re-scaled the hp axis. If you fix the hp axis, the crossover is at (or eyballing it) 5252.
SolsticeMan is offline
