A/C died while driving - Pontiac Solstice Forum
 11Likes
post #1 of 27 (permalink) Old 07-17-2019, 05:33 PM Thread Starter
sirwm's Avatar
it is 90+ degrees in NJ today.
During a drive, the Air Conditioner in my GXP automatic coupe stopped blowing cold air.
Only hot air...
...worked in the morning, but stopped working during the evening drive...
All lights on the dials are working.
No codes thrown...
I did the Actuator Recalibration procedure from here -> https://www.solsticeforum.com/forum/...14/#post964737, but no change.
...just hot air...
any ideas on where to start to diagnose this? I have just started searching for older threads... tough to search with inconsistent terminology...
Sir William's Fleet
sirwm is offline
post #2 of 27 (permalink) Old 07-17-2019, 07:03 PM
chickenwire's Avatar
Probably need to recharge it. Not difficult, but it begs the question where/how did it leak?
I had to recharge my '07 NA the year after I bought it - 2013. it's been fine since.
chickenwire is offline
post #3 of 27 (permalink) Old 07-17-2019, 08:13 PM
If it happened suddenly, I doubt it's a recharge issue (well, unless you got a massive freon fracture). Hoping that it's not a compressor issue - but at least check the belts anyway.
It could be that the blend flap actuator has failed, it's not uncommon. Replacements are pretty cheap and you can DIY, though you need to be somewhat of a contortionist. Some instruction on replacement is here: https://www.solsticeforum.com/forum/...1/#post1607249 But before you buy a new one, you may want to follow the first few steps to see if the flap is working or not.
sirwm, Sting Ya and raygun like this.
post #4 of 27 (permalink) Old 07-17-2019, 08:13 PM
Certainly have the refrigerant checked, but I have usually heard of that being a gradual loss of cooling, and not a sudden one.
You didn't mention fuses, so have you checked? Fuse 22 Underhood. Also Fuse 16 in the BCM, but that powers other things too, so probably not.
You should be able to hear or see the compressor clutch engage if you turn it on and off with the hood open.
There isn't much else you can check without a diagnostic scanner.
sirwm likes this.
post #5 of 27 (permalink) Old 07-18-2019, 05:24 AM
Soup - does the diverter "default" to heat when it fails or stay stuck where it was?
post #6 of 27 (permalink) Old 07-18-2019, 06:31 AM
Frankly, I've no idea. I guess it would depend on if the flap connection breaks or if the motor fails...
In any case, that's why I said he should visually check if it HAS failed, before replacement.
Sting Ya likes this.
post #7 of 27 (permalink) Old 07-18-2019, 07:11 AM
Check the AC fuse. When they blow out, the AC motor stops running. Hope this helps.
munaman is offline
post #8 of 27 (permalink) Old 07-18-2019, 07:44 AM
showtime's Avatar
I had a similar issue and it was a loose connector behind the glove box.
showtime is offline
post #9 of 27 (permalink) Old 07-18-2019, 11:27 AM
I'm with Soup on this one had this happen recently to the Grand Marquis sudden loss of cooling and blowing hot air (blend flap actuator door ) .I would not try to recharge it until you find out for sure what the problem is you run the risk of overfilling the system ask me how I know .
Sting Ya is offline
post #10 of 27 (permalink) Old 07-18-2019, 01:24 PM
Rusty Boltz's Avatar
Only hot air..
No codes thrown...
...just hot air...
First step would be to determine if it's ambient air or heated air.
'07 Sky
2.4L
5 speed
limited slip
chrome
leather
bright interior trim
Monsoon audio
AM/FM/XM/CD changer
Rusty Boltz is offline
post #11 of 27 (permalink) Old 07-18-2019, 01:38 PM
Check the refrigerant, Yes. Recharge the refrigerant without knowing that it is low, No.
Sting Ya and Rusty Boltz like this.
post #12 of 27 (permalink) Old 07-18-2019, 01:40 PM
Hmmmm. Great name for a band!
showtime and raygun like this.
post #13 of 27 (permalink) Old 07-18-2019, 01:52 PM
Hot Air and the Freon Fracture!
sirwm likes this.
post #14 of 27 (permalink) Old 07-18-2019, 05:22 PM Thread Starter
sirwm's Avatar
fuse 22 is good
relay 15 is good too. ( we swapped the relay with the trunk release to prove it... )
( also we could hear the relay click when we activated the a/c )
when the car first starts , and I put the a/c on, there is no heat coming out - just room temperature air
Sir William's Fleet
sirwm is offline
post #15 of 27 (permalink) Old 07-18-2019, 06:13 PM Thread Starter
sirwm's Avatar
found this thread... https://www.solsticeforum.com/forum/...acement-75243/
this sounds like my problem...
...feels like a trip to the dealer to get the a/c clutch checked. ( and probably a whole new compressor )
Sir William's Fleet
sirwm is offline
