Fog lights not working and weird radio issue - Pontiac Solstice Forum
 2Likes
  • 1 Post By joybill44
  • 1 Post By sirwm
post #1 of 6 (permalink) Old 03-31-2019, 02:19 PM Thread Starter
Rick Bennett's Avatar
I bought a wrecked 2008 NA Solstice, fixed it this past winter ..... Drove is for the first time this past weekend.
The fog light switch doesn't do anything, fog lights don't work and the switch feels like it isn't 'working' when you push it on ..... I have checked the fuses .... Any ideas ?
Next, while driving down the road the radio switches (by itself) between radio and auxiliary input. There is nothing plugged into the auxiliary plug. Sometimes it switches every 5 seconds and other times I could listen to the radio for 20 minutes before it switched to auxiliary
Rick Bennett is offline
post #2 of 6 (permalink) Old 03-31-2019, 05:15 PM
joybill44's Avatar
had the same problem with my fog light switch. Took it out and sprayed it inside with contact cleaner. worked fine for about a year. Quit working again and I bought a new one on eBay. end of problem. Don't have to remove dash to replace, just remove chrome instrument bezel, black inner instrument tunnel under bezel, and you can reach the foglight button release tabs with some needle nosed pliers.
there are two different types of buttons, lit and unlit. be sure and get the one with the built in LED bulb.
Bill
Rick Bennett likes this.
joybill44 is offline
post #3 of 6 (permalink) Old 03-31-2019, 07:08 PM Thread Starter
Thanks Bill, found one on Rock Auto for $15
post #4 of 6 (permalink) Old 04-01-2019, 05:17 AM
sirwm's Avatar
get a can of air, and blow the air in the area of the aux connector.
Strange things have been reported before , and this was one solution.
( also inserting and removing an appropriate plug from that connector while doing the air... )
Sir William's Fleet
sirwm is offline
post #5 of 6 (permalink) Old 04-01-2019, 01:55 PM Thread Starter
Thank you, I'll try this
post #6 of 6 (permalink) Old 04-04-2019, 02:09 PM Thread Starter
Bill
Thanks again .... New switch fixed it !
edit - Fog light part number (AC Delco) 15850572
Similar Threads
Weird radio issue... tntblondy General Tech, Platform Common Issues & Solutions 14 09-26-2017 05:42 PM
Radio Buttons Not Illuminating Red at night...dimmer also not working Nick5216 General Solstice Discussion 0 09-14-2011 10:01 PM
Fog Lights...Turn Lights... All sorts of lights Roxtogo Mods - Interior/Exterior Functional/Appearance 1 03-03-2007 05:49 PM
Fog Lights Not Working smartin General Tech, Platform Common Issues & Solutions 15 03-23-2006 06:07 AM
