LNF vs LE5 intake manifold - Pontiac Solstice Forum
 1Likes
  • 1 Post By JohnWR
post #1 of 5 (permalink) Old 05-11-2019, 02:35 PM Thread Starter
So,
Why is the LNF intake manifold cast aluminum, while the LE5 is (pretty typical) plastic?
post #2 of 5 (permalink) Old 05-11-2019, 06:26 PM
So, Why is the LNF intake manifold cast aluminum, while the LE5 is (pretty typical) plastic?
Maybe because the LNF manifold has to withstand 15+ psi of internal pressure at elevated temperatures?
post #3 of 5 (permalink) Old 05-21-2019, 12:27 PM Thread Starter
I can understand your train of thought. But, even the coolant reservoir has to maintain ~14psi, and I can't imagine that temperatures on that side of the head are significantly greater on the LNF than they are on the LE5. There are quite a few boosted engines out there with composite intake manifolds.
post #4 of 5 (permalink) Old 05-21-2019, 01:32 PM
I thought some more after I posted that, and it could be precautionary because of the direct injection. The LNF was GM's first DI application, and they could have been concerned about backfire, which has been a concern with DI.
Obviously I am guessing, but it is an entertaining thought experiment.
raygun likes this.
post #5 of 5 (permalink) Old 05-21-2019, 01:42 PM Thread Starter
Makes as much sense as anything else that's come to mind.
Similar Threads
LSJ M62 and Intake Manifold on LE5 in a Solstice rhit_rs Forced Induction 2.4 l Ecotec 37 08-18-2013 12:36 PM
LNF Aftermarket Intake Manifold!! New 40rty Mods - Engine 2.0 Turbo 4 11-08-2012 10:36 AM
LNF exhaust manifold and k04 on LE5 2.4solstice06 Forced Induction 2.4 l Ecotec 7 07-21-2012 07:14 AM
Ambient Air temp vs Intake Manifold Air temp "Maine"-iac Forced Induction 2.4 l Ecotec 9 05-13-2009 06:16 PM
Cobalt SS LNF Vs. GXP LNF specki Mods - Engine 2.0 Turbo 34 03-16-2009 10:44 AM
