new whistle/squeal on tight right turn - Pontiac Solstice Forum
 2Likes
post #1 of 18 (permalink) Old 03-13-2019, 01:52 PM Thread Starter
sirwm's Avatar
on my automatic gxp coupe with gmpp parts/tune and 58k miles,
I am now hearing for about a week a
whistle or squeal when I do a tight right turn, like having the car
do the tightest right turn in a circle that it can do.
( car is moving of course. When the car stops, the noise stops )
It is not a grind noise.
The brakes and rotors were changed within the last 8k miles.
The car runs fine in all other ways...
anybody have an idea as to what this squeal may be ?
Sir William's Fleet
sirwm is offline
post #2 of 18 (permalink) Old 03-13-2019, 03:49 PM
4501 Safari's Avatar
A suggestion...Check your power steering fluid. If you have never changed it, do so and you may find the noise goes away and the car feels better. I used a Mityvac MVA6851 Fluid Extractor, Amazon: https://www.amazon.com/Mityvac-MVA68...gateway&sr=8-2 Clean with denatured alcohol. It's good for the trans, Differential, brake reservoir and clutch. Truly a case of having a tool that sucks is a good thing. One of the better new purchases and as good, while much less fragile than the veterinary glass syringe I have used and retired.
Good luck.
Richard Snipes
raygun likes this.
4501 Safari is offline
post #3 of 18 (permalink) Old 03-13-2019, 07:18 PM
wmf246's Avatar
power steering belt slippage??
Bill
wmf246 is offline
post #4 of 18 (permalink) Old 03-14-2019, 03:21 AM Thread Starter
sirwm's Avatar
the sound seems to match the rotation of a tire...
louder then softer then louder etc.
I will check the power steering fluid anyway. I did change the fluid back at the 10k mile mark
( 2.5 years ago )
using the OEM stuff for colder weather.
Sir William's Fleet
sirwm is offline
post #5 of 18 (permalink) Old 03-14-2019, 06:15 AM
Power steering noise is usually not dependent on the car moving, it only requires you to turn the wheel hard in one direction or the other.
Could it be tire squeal? My NA will frequently squeal a tire in a tight turn, probably due to the LSD and touring tires. My RL, with LSD but higher-performance tires , does not do it.
Also check the tires for any rubbing, and make sure that your hub bolts are tight.
JohnWR is online now
post #6 of 18 (permalink) Old 03-14-2019, 08:17 AM Thread Starter
sirwm's Avatar
I've had the tires squeal before. This sounds different to me, but I will check the tire pressure anyway... thanks
Sir William's Fleet
sirwm is offline
post #7 of 18 (permalink) Old 03-14-2019, 08:37 AM Thread Starter
sirwm's Avatar
Here is a thread/post that implies power steering issue on turns...
https://www.solsticeforum.com/forum/...55/#post804310
( My noise is definitely not this noise )
Here is a post from "Small Dealer" about which powersteering fluid to use in cold weather to stop a growl...
https://www.solsticeforum.com/forum/...55/#post814280
And here is a post from "Small Dealer" on how to check and change the fluid...
https://www.solsticeforum.com/forum/...51/#post628587
Sir William's Fleet
sirwm is offline
post #8 of 18 (permalink) Old 03-14-2019, 08:45 AM Thread Starter
sirwm's Avatar
here is another thread with weird sounds
and steering that I need to review:
https://www.solsticeforum.com/forum/...g-fixed-35192/
Sir William's Fleet
sirwm is offline
post #9 of 18 (permalink) Old 03-14-2019, 08:55 AM Thread Starter
sirwm's Avatar
here is another power steering noise thread:
https://www.solsticeforum.com/forum/...ng-belt-47036/
However, this noise was constant even when the car was not moving.
( not my noise )
But buried in the thread is a mention that the power hose got crimped on someone's car...
Sir William's Fleet
sirwm is offline
post #10 of 18 (permalink) Old 03-14-2019, 08:56 AM
It was a reach, but I decided to cover all of the possibilities that i could think of, even if they didn't completely make sense.
Also, the sound I get when turning in not the same as a low-pressure squeal, it is more like the tire is spinning or dragging.
post #11 of 18 (permalink) Old 03-14-2019, 08:59 AM Thread Starter
sirwm's Avatar
found this post talking about the steering wheel shaft needing some love...
https://www.solsticeforum.com/forum/...07/#post617618
...a squeak when turning the wheel in park lots that sounds like geese (fixed with a little lube on the grommet that the steering shaft runs through)....
Sir William's Fleet
sirwm is offline
post #12 of 18 (permalink) Old 03-14-2019, 04:39 PM Thread Starter
sirwm's Avatar
the power steering fluid level looks fine, and the hose looks fine too...
... continuing to search...
Sir William's Fleet
sirwm is offline
post #13 of 18 (permalink) Old 03-15-2019, 04:25 PM
BritSolDriver's Avatar
I had something similar with an automatic NA 2006 a few years ago.
I can't remember the exact details, but something was loose on the brakes that also had new pads & rotors within the previous few 3000-4000 kms.
BritSolDriver is offline
post #14 of 18 (permalink) Old 03-20-2019, 01:51 PM Thread Starter
sirwm's Avatar
I have a service appointment on 3/21/19 to have this noise investigated...
Sir William's Fleet
sirwm is offline
post #15 of 18 (permalink) Old 03-20-2019, 03:54 PM
pands's Avatar
rack and pinion?
Hello, as you have described the sound, I had a similar squeal that, after inspection was rack and pinion failure. Check the rubber boots to see if they have any fluid inside them. I had it replaced and have had no sounds or trouble since.
sirwm likes this.
pands is offline
Similar Threads
Engine Squeal At 2700 RPM's kappacar General Solstice Discussion 6 02-10-2011 10:02 PM
Brake Pedal Squeal, Where can I buy this part? Supereco06 General Tech, Platform Common Issues & Solutions 5 10-10-2010 01:48 PM
Squeal when in reverse 2 007 Silver Mods - Engine 2.4 l Ecotec 3 07-08-2009 11:01 PM
New OnStar Turn-By-Turn Upgrade Announced Small Dealer Solstice and other Automotive Related News 2 04-26-2007 03:02 AM
Can the Solstice squeal its tires?? [Yes] MisterE General Solstice Discussion 44 02-25-2006 07:29 PM
