No power anywhere! Good battery - Pontiac Solstice Forum
 2Likes
  • 1 Post By JohnWR
  • 1 Post By JohnWR
post #1 of 7 (permalink) Old 03-22-2019, 08:55 AM Thread Starter
fullytweaked's Avatar
Ive been driving my 2008 automatic with no issues since getting the transmission computer replaced. Yesterday I went to start the car after being in a store for 10 minutes. No lights, no accessories, no start, nothing. Wouldn’t even let the key back out.
I have checked voltage at the battery and at the lug on the fuse box. Both fine. The hazards will not work, the trunk release will not work. I hadn’t to use the release to get the key out.
What could cause this? Is there a master fuse that I’m not aware of?
2006 2.4L
Water damaged from an insurance sale.
fullytweaked is offline
post #2 of 7 (permalink) Old 03-22-2019, 09:13 AM
If there is a master fuse I haven't seen or heard of it, so probably not.
Where did you reference 0V for your voltage checks? If you used the battery it could be a ground problem. Be sure to check voltage to the frame.
Nearly everything operates under control of the BCM, and it sits low in the car so could have been damaged in the flood. It may also shut down if one of the LANs is disconnected.
If the main ground is good I would check voltages at some of the "always hot" fuses to find out where there is and isn't power.
I would direct you to them but do not have a manual handy. I will tonight if someone doesn't beat me to it.
Sting Ya likes this.
JohnWR is online now
post #3 of 7 (permalink) Old 03-22-2019, 10:02 AM
Sting Ya's Avatar
Agree with John if this is a flood car you could have corrosion on a connector that has taken some time to affect the electrical system especially if it was salt water .
Sting Ya is offline
post #4 of 7 (permalink) Old 03-22-2019, 10:05 AM
There are a number of BCM fuses that can act like 'master' fuses. Check the big square fuses (#'s 4, 5 & 7) in the underhood fuse block in the row at the end nearest the fender.
post #5 of 7 (permalink) Old 03-22-2019, 10:17 AM
ChopTop's Avatar
Just posted this the other day, Location of all grounds: https://www.solsticeforum.com/forum/...rounds-127585/
BTW, what is a transmission computer, and why was it replaced?
ChopTop is online now
post #6 of 7 (permalink) Old 03-22-2019, 06:20 PM
Another possibility is BCM fuse 26, labeled DR LCK. It appears to power the BCM itself in addition to the door locks.
That one and UFB fuse 7 (BCM) look to be the only ones that would kill everything by themselves.
With any other fuses it looks like something would still work, unless several blew at one time.
raygun likes this.
post #7 of 7 (permalink) Old 03-28-2019, 04:28 PM
I believe OP was referring to the transmission control module (TCM). On the autos, it's a separate module sandwiched in next to the ECM, IIRC.
raygun is online now
Similar Threads
2006s-No Start after Battery Disconnect or Dead Battery Event Small Dealer General Tech, Platform Common Issues & Solutions 3 10-26-2006 09:25 AM
Any Dealerships in WA pricing anywhere near MSRP? TAF_CJN Getting Your Solstice 5 05-23-2006 06:02 PM
Can't find one anywhere :( Sunmoon Getting Your Solstice 11 11-29-2005 06:50 AM
Solstice available anywhere? newfan General Solstice Discussion 15 06-18-2005 08:02 AM
