rear Axle Leak again after 2nd seal installed at GM dealer. - Pontiac Solstice Forum
 5Likes
  • 2 Post By 44thSKY
  • 1 Post By JohnWR
  • 1 Post By rob the elder
  • 1 Post By JohnWR
post #1 of 10 (permalink) Old 04-04-2019, 07:30 PM Thread Starter
Hi, Would like your input on my issue with my 2008 Pontiac Solstice GXP.
I keep my car parked indoor at winter time ( MN), had the chance to run it 3 time when it was 20 degrees . after parking I saw a small leak at the back. been told that its the seal shrinking and expanding due to the cold and the card running. and a small leak is not a big deal and needs to be checked if its keep happening at the summer time.
moving forward... I got the car to GM dealer for an oil change before the summer start and told them about the small leak... they recommended to fix it.
They replace the left axle seal, after getting home (15 miles) I saw it leaking again.
following morning I came again to the dealership..., they said that it can be a faulty seal. they replace the seal again with applying anaerobic sealer. ( been told that the 1st seal was defective and had a punch on it... maybe from incorrect installation...? who knows...)
came home again to find out that there is still a leaking
Any advice?
efisal is offline
post #2 of 10 (permalink) Old 04-05-2019, 08:39 AM
44thSKY's Avatar
I'd go back to the dealer. But, watch for the answer being a different seal, maybe?? Might tell you a lot about the dealer's organization. Folks on this forum might have a bit of knowledge of what that answer might involve. Keep us posted then.
Sting Ya and easyryderca like this.
44thSKY is offline
post #3 of 10 (permalink) Old 04-05-2019, 09:25 AM
Sting Ya's Avatar
The problem I've run into with my car is that just because it's a GM dealer does not mean they are familiar with our cars . I would try to find an ex Pontiac dealer , my local dealer became a Buick /GMC truck dealer also the rear end on our cars was also used on a Cadillac CTS another option . I have to believe from what you described is an improper installation and who knows with all the cheap Chinese replacement parts flooding the US market you may have ended up with another bad seal it's not uncommon .Good Luck !
Sting Ya is offline
post #4 of 10 (permalink) Old 04-05-2019, 10:05 AM
The end of the axle is splined and there is a sleeve available to cover the splines to keep them from cutting the seal during installation.
It is also possible that the surface of the axle shaft is damaged where the seal runs. Even cheap seals are unlikely to leak immediately.
Sting Ya likes this.
post #5 of 10 (permalink) Old 04-05-2019, 01:39 PM Thread Starter
is this sleeve is universal or special tool specific to the Pontiac Solstice?
efisal is offline
post #6 of 10 (permalink) Old 04-05-2019, 03:36 PM
It is identified as a J 44394 Seal Protector. Most of the listings I have seen refer to J 44394-A or "similar to", and is a set of 10.
It is applicable at least to the Solstice, Sky, and 2006-7 Cadillac CTS, CTS-V, and DTS, as well as most 2011 and later GM vehicles.
post #7 of 10 (permalink) Old 04-05-2019, 09:19 PM
I have about six. Blue plastic tool that slips over the end of the axle during install. Without it the seal gets cut. Found on Amazon. Basically a throw away tool that can be used once or a few times and discarded
Not sure if it's this one but it's like this
https://smile.amazon.com/OTC-Tools-6...y&sr=8-1-fkmr2
post #8 of 10 (permalink) Old 04-06-2019, 09:47 AM
No. The recall was for the pinion shaft seal. This discussion is about one of the axle shaft seals.
Some confusion arises because the official name of the unit that most people call the differential is "drive axle".
ChopTop likes this.
post #9 of 10 (permalink) Old 04-06-2019, 10:42 AM
ChopTop's Avatar
Deleted my post to avoid confusion.
ChopTop is offline
post #10 of 10 (permalink) Old 04-18-2019, 12:56 PM Thread Starter
Update: Came back from 3rd Seal replacement
Update:
So I decided to get this tool ( Kent Moore J-44394 Axle Seal Protector, $10 on ebay) and go to the dealer and explained to them that after research, most likely they are damaging the seal during the installation and they need this tool.
They take it pretty nice....lol ( I didn't want to sound like a smart a**SS ) .
left the car At GM for 1 day to run it and make sure no leaks. Picked it up today and been told that they actually have this type of tool, but they use what I got them.
They did indicate that the Axel rod that slides in was not smooth, but it not likely to be the problem.
So far no leak any more (after 25 miles driving) ..... Finger crossed
efisal is offline
Similar Threads
Axle Seal Replacement - DIY Teresa H Mods - Handling / Chassis / Suspension / Brakes / Steering 2 08-30-2014 01:37 PM
Recall Drive Axle Seal Leak-Replace Seal 2/1/08 Small Dealer General Tech, Platform Common Issues & Solutions 53 03-29-2012 09:33 PM
More info. on rear diff. pinion seal leak..... quincy General Solstice Discussion 4 02-04-2009 04:56 PM
Recall for rear axle pinion seal gmowner8 General Tech, Platform Common Issues & Solutions 6 12-22-2007 05:02 AM
SMALL oil leak - rear main seal? WhippetRun General Tech, Platform Common Issues & Solutions 27 06-21-2006 10:30 PM
