a recall on wiring harness ? - Pontiac Solstice Forum
 7Likes
post #1 of 24 (permalink) Old 08-23-2019, 05:45 AM Thread Starter
sirwm's Avatar
some people on facebook are talking about a recall on a wiring harness.
new parts:
10397098 Blower Motor Resistor
84014104 Wire Harness
anybody here have any information ?
( I never got any recall paperwork... )
Sir William's Fleet
sirwm is online now
post #2 of 24 (permalink) Old 08-23-2019, 05:52 AM
Administrator
MomsSol's Avatar
Here is info
https://static.nhtsa.gov/odi/rcl/201...5V421-2881.pdf
I believe there was also a recall on 2005-06 Chevy Silverado.
easyryderca likes this.
Team Solstice
NASSOA(TM)
MomsSol is offline
post #3 of 24 (permalink) Old 08-23-2019, 05:57 AM
Some H3 Hummers were recalled for that, but it was not expanded to us.
If you are curious about any recalls for your vehicle, go here: https://www.nhtsa.gov/recalls and enter your VIN.
post #4 of 24 (permalink) Old 08-24-2019, 02:20 AM
RedOne07's Avatar
That is a very helpful URL , but be aware it only lists unrepaired recalls.
RedOne07 is offline
post #5 of 24 (permalink) Old 08-24-2019, 07:32 AM
joybill44's Avatar
checked my VIN against NHTSA and GM and apparently this does not apply to sons.
Bill.
joybill44 is offline
post #6 of 24 (permalink) Old 08-24-2019, 07:35 AM
joybill44's Avatar
I meant sols
Bill
post #7 of 24 (permalink) Old 08-24-2019, 10:08 AM
shabby's Avatar
Same thing happens to the plug from the fan relay to the cooling fan.
2008 solstice gxp - Solo Performance 3" mach exhaust + hiflow cat - dyno sheet
shabby is offline
post #8 of 24 (permalink) Old 08-24-2019, 01:27 PM
You'd think that, if they're issuing a recall do to a bad part, that they'd issue the recall for all of the vehicles that have that part. I've had this problem on both of my Solstices.
I had the same issue with my 4Runner. There's a really crappy vacuum switching valve on the 4.7L conveniently located under the intake manifold ($$$) that likes to go bad. They recalled the Tundra and Land Cruiser, but not the 4Runner that uses the same engine.
I wound up getting a bypass module rather than tearing the top of the motor apart. That manifold is not simple to remove.
raygun is online now
post #9 of 24 (permalink) Old 08-24-2019, 02:11 PM
ChopTop's Avatar
Calling @TomatoSoup pics if you do this repair.
Someone on FB does stated that it has something to do with always having the fan on high?
ChopTop is offline
post #10 of 24 (permalink) Old 08-24-2019, 09:48 PM
The consensus is if you stay at 1,2 or 3 but NOT 4 fan speed you are fine. Apparently if you run the HVAC fan on high for an extended period of time you risk the meltdown. I don't use high ever
post #11 of 24 (permalink) Old 08-25-2019, 07:54 AM
chickenwire's Avatar
Mine did not melt there, but at the connector under the BCM. And it melted there when running the blower on high for an extended period of time (driving top down after sunset on a chilly evening and my better half was cold.)
chickenwire is offline
post #12 of 24 (permalink) Old 08-25-2019, 03:52 PM
easyryderca's Avatar
I remember reading about this issue in a thread back in 2015. After reading it i had my solstice taken to my local G.M.Dealership & had the blower motor resistor & the connector harness changed.
They installed resistor oem part was 10397098 .
They installed harness oem part number 25949869 .
So far so good.
ChopTop likes this.
easyryderca is offline
post #13 of 24 (permalink) Old 08-25-2019, 04:31 PM
I us high quite often on in mine. but not for long, just to blow out the 247 degree hot florida air out of the ducks and cockpit. then down to 2 them 1 most of the tyme. Ive seen lotsa burnt connectors on many different cars. just go's to show engineers dont always know what works and what dont.
marksbug is offline
post #14 of 24 (permalink) Old 08-25-2019, 07:41 PM
Bama's Avatar
I just learned something new.
Just An Ordinary Average Guy
With A Super Cool Car!
Bama is offline
post #15 of 24 (permalink) Old 08-26-2019, 08:29 AM
I just fixed mine for the same exact issue.
2007 Solstice GXP
laser411 is offline
