Replacing water pump and dropping a bolt - Pontiac Solstice Forum
 9Likes
post #1 of 19 (permalink) Old 03-03-2019, 06:44 PM Thread Starter
Send a message via Skype™ to fezfernando
So Iím replacing the water pump on my 08 GXP. Iím following the DDMWorks recommendation for replacement (although the turbo is burning oil so it needs replaced too). I used the half moon tool to hold the sprocket in place. When I was trying to locate the holes to reinstall the pump on the gear, I dropped a 2Ē bolt in to the engine.
How screwed am I?
How much effort will it be to remove the front of the engine to access the timing chain and hopefully the bolt?
fezfernando is offline
post #2 of 19 (permalink) Old 03-03-2019, 06:50 PM
Alannn's Avatar
Try something like this first:
Flexible Magnetic Grabber Pickup Tool
https://www.amazon.com/RAM-PRO-Flexi...6EHBESCT8MJSTA
2007 GXP Pure
Probeam/Backbone/Trifecta Tune
Alannn is offline
post #3 of 19 (permalink) Old 03-03-2019, 07:35 PM
joybill44's Avatar
I've retrieved a lot of bolts over the years with those handy magnet grabbers.
joybill44 is offline
post #4 of 19 (permalink) Old 03-03-2019, 07:43 PM
syjos's Avatar
Those are lifesavers.
There is only one difference between a handy person and one that is not.
The handy person knows how to correct, cover up or hide mistakes.
syjos is offline
post #5 of 19 (permalink) Old 03-03-2019, 07:46 PM
Saveaux's Avatar
This type is neat too, pull trigger to energize the magnet.
https://rover.ebay.com/rover/0/0/0?m...2F113350061611
Saveaux is offline
post #6 of 19 (permalink) Old 03-04-2019, 02:28 PM
Dave@ddmworks's Avatar
How screwed am I?
Hopefully one of the suggestions offered so far will help you with getting the bolt. Make sure to use a lot of Vasoline or grease to hold the bolts to the socket when doing the install. There is a little pocket down below the water pump that hopefully caught the bolt and if so, with a magnet you might be able to retrieve it. In the picture you will see what is below the water pump (big round hole) and I am pointing to the little pocket below that hopefully caught it.
If you can not get it out, you will need to remove both belts from the engine, the crank pulley and the front plate. Once those are removed you will have access to basically anywhere the bolt would have went, unless it went all the way into the oil pan.
Hope that helps,
Dave
Name:	DDMWorks Engine without timing.jpg
easyryderca, raygun and Tronak like this.
Dave Michel
DDMWorks
Sales - 864-438-4949
Tech Support - 864-907-6004
WWW.DDMworks.com
[email protected]
post #7 of 19 (permalink) Old 03-04-2019, 04:09 PM
Thanks Dave. Helpful as always
rob the elder is online now
post #8 of 19 (permalink) Old 03-05-2019, 09:15 AM
On a side note: this is one reason that I like the full circle tool rather than the half-circle version. At least on the one I have, the holes to access the screws in the pump gear were pretty deep, and made it a lot harder to drop a bolt. (It also nicely covers up the rest of the opening, and bolts to the timing cover in four places.)
Removing the valve cover may give you better access to get the magnet tool down where it needs to go, depending on where it landed.
post #9 of 19 (permalink) Old 03-05-2019, 11:21 AM
wspohn's Avatar
I like that trigger operated magnetic pick up - without that, they try to glom onto everything on the way down.
This post brings back nightmares of doing a valve job on a Jaguar straight 6 in the car and dropping one of the cam sprocket bolts into the timing case while reassembling and gearing it hit things all the way down. Fortunately it made it into the sump so a fairly easy resolution.
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #10 of 19 (permalink) Old 03-05-2019, 11:40 AM
My dad dropped a very small aluminum thing (I don't recall what it was) into one of the cylinders while changing plugs on a first generation 300ZX.
Fun thing about AL: magnets don't work as well as one might hope.
post #11 of 19 (permalink) Old 03-05-2019, 06:22 PM
Saveaux's Avatar
Not to derail this thread, but all this talk of graspers reminds me of claw graspers.
It's not that magnets are new technology, but I remember growing up only having the flexible "claw" graspers and not a magnetic type.
These things were a joke. I remember trying to unsuccessfully pick things up pretty often.
Do you have or remember these things?
Ours did NOT have a fancy light on it like this one...
Flexible Claw Pick Up Tool 4 Claw LED Alloy Shaft Universal Magnet Lighting Multifunction Collect Grabber Tools https://www.amazon.com/dp/B07H984GC5..._hOWFCbASTGZHD
Saveaux is offline
post #12 of 19 (permalink) Old 03-05-2019, 07:51 PM
syjos's Avatar
I have several of those graspers and they are indispensible on boats. Drop a bolt on a car in the engine compartment and it usually falls to the ground, unless you drop it into the engine. On a boat, it drops into the bilge, under the engine or a spot that is unreachable. Most fasteners used on boats are non magnetic stainless so magnetic pickups are useless.
One of my claw grabbers has a 4 foot extension to get way under things.
rob the elder likes this.
syjos is offline
post #13 of 19 (permalink) Old 03-06-2019, 12:22 PM Thread Starter
Hope that helps,
Dave
Thanks Dave for the suggestion on where it might have landed. The magnetic ďwormĒ I ordered arrived today. Hopefully, Iíll be able to find it this evening. I really wish I would have known about the full circle tool. I would have DEFINITELY used that instead, knowing what I know now.
post #14 of 19 (permalink) Old 03-06-2019, 02:49 PM Thread Starter
Update: I FOUND IT!!!
Thatís the best $13 I have ever spent on a tool.
If anyone is looking for such a tool: https://www.google.com/search?q=v8+t...26+mighty+worm
easyryderca, joybill44 and raygun like this.
post #15 of 19 (permalink) Old 03-06-2019, 03:26 PM
Congrats! Glad to hear you found it
RobR is offline
Similar Threads
Water pump bolt size? raygun General Tech, Platform Common Issues & Solutions 4 05-15-2017 11:33 AM
Water pump - Fuel pump question wildfiglane General Tech, Platform Common Issues & Solutions 10 01-19-2016 08:25 PM
GXP water pump change out, pictures, procedures, details and videos duckSol General Tech, Solstice GXP Specific 2 06-14-2015 06:15 PM
Missing hub bolt and sway bar bolt Thomas Autocross and Racing Discussion (Solstice/Kappa) 8 12-15-2010 10:30 AM
