Replacing water pump and dropping a bolt - Page 2 - Pontiac Solstice Forum
 9Likes
post #16 of 19 (permalink) Old 03-06-2019, 09:13 PM
Sweet! Glad it worked out.
post #17 of 19 (permalink) Old 03-07-2019, 08:00 AM
showtime's Avatar
I know it doesn't help with the OP problem as he fixed it but I bought an endoscope for less than $10 to plugs into my phone and works great. If you attach it to the magnet/grabber you can see to guide it where you need it.
raygun and syjos like this.
showtime is offline
post #18 of 19 (permalink) Old 03-08-2019, 04:03 PM
Any chance someone has a part number for the full circle tool?
Tronak is offline
post #19 of 19 (permalink) Old 03-08-2019, 04:05 PM
@Tronak
https://www.amazon.com/gp/product/B001C6P0NS/
OTC 6616
That's the one I used. It's great. It also screws into all three holes on the water pump gear, whereas the half-moon tool uses two. I like to plan for things going sideways. Belt + suspenders.
If you wind up using the half-moon tool, it might make more sense to put it upside down - covering the top of the hole instead of the bottom - as that feels like it might be better at preventing things from falling in.
Or, just spend the extra $15 and cover the whole thing up.
Similar Threads
Water pump bolt size? raygun General Tech, Platform Common Issues & Solutions 4 05-15-2017 11:33 AM
Water pump - Fuel pump question wildfiglane General Tech, Platform Common Issues & Solutions 10 01-19-2016 08:25 PM
GXP water pump change out, pictures, procedures, details and videos duckSol General Tech, Solstice GXP Specific 2 06-14-2015 06:15 PM
Missing hub bolt and sway bar bolt Thomas Autocross and Racing Discussion (Solstice/Kappa) 8 12-15-2010 10:30 AM
