Solstice GM Part Numbers - Page 13 - Pontiac Solstice Forum
post #181 of 192 (permalink) Old 06-09-2012, 02:42 PM
Pure-Sol's Avatar
Originally Posted by SolNut View Post
Which Side?
Oops, forgot to mention it was the driver's side. I didn't make the same mistake doing the passenger side haha
Edit: Just saw Gunny's response. Thanks!
Edit2: actually, looking at the description on a website, I think that's the wrong one I was looking for. When I said the interior door handle, I meant the part you yank on to shut the door when you're inside.
'06 Pure Sol: Kappashield, lil Chromies, Pioneer AVIC-x920BT, M1 wheels, blacked out grille, SOLO from head to tail with Norm's sweet center exit diffuser. DDM Stage II (#13, eat it bad luck)! God it's fast now!
TEAM DDMWORKS
License Plate: PURSOL
Pure-Sol is offline
post #182 of 192 (permalink) Old 06-09-2012, 02:56 PM
Pure-Sol's Avatar
So, after some searching I've found the part number. It's 907916 for the driver's side in grey. Unfortunately it's no longer in stock anywhere. I may have to glue it
TEAM DDMWORKS
Pure-Sol is offline
post #183 of 192 (permalink) Old 06-09-2012, 03:34 PM
jeffgtx's Avatar
What tabs could you break on the handle?
Jeffgtx's Shades Of Gray Pontiac Armada
jeffgtx is offline
post #184 of 192 (permalink) Old 06-09-2012, 10:13 PM
Pure-Sol's Avatar
Yeah, so it's not the handle. It's the triangle-ish plastic piece under the handle you pull to shut the door when you're inside. Behind it is two bolts that you have to remove to take off the inner door liner. It's held on with three plastic tabs and one of those plastic screws that you just yank out instead of screw out.
TEAM DDMWORKS
Pure-Sol is offline
post #185 of 192 (permalink) Old 06-10-2012, 01:17 AM
jeffgtx's Avatar
number 8 here? if so you can get them. i have purchased the sky version many times.
try giving tom at crate engine depot a call.
jeffgtx is offline
post #186 of 192 (permalink) Old 06-10-2012, 08:57 AM
Pure-Sol's Avatar
Yep, that's the one Jeff, thanks! I searched on a bunch of websites and they only had ebony available. I'll try Tom on Monday. Thanks for the info!
TEAM DDMWORKS
Pure-Sol is offline
post #187 of 192 (permalink) Old 06-19-2012, 05:07 AM
15827960 seatbelt bezel driver side $4.07
19212670 performance upgrade kit $530.15
fosti is offline
post #188 of 192 (permalink) Old 06-19-2012, 05:23 AM
Part #907914 ebony $15.89 gmpartsgiant.com
fosti is offline
post #189 of 192 (permalink) Old 08-20-2012, 08:08 AM
LowLife1's Avatar
*2009/10 Rear window glass hatch
*Note this is the glass coupe hatch P/N (not the rear window on the vert).
P/N 20823455
Dealership price as of 8/20/12
$875
2006/#482/First 1,000/Triple Blk/2.4 Manual/BCCoilovers/JPM Shifter (classic white w/black 5spd pattern)
2009/#480/GXP of 1266 Targa Coupes/Aggressive/Silver Metallic Stripe/Auto/Optional Polished Split Spokes/GMPP/Solo Mach Shorty/Norms Front GXP Splitter/BCCoilovers/DDM Backbeam & Probeam
LowLife handle simply means likes lowered cars
LowLife1 is offline
post #190 of 192 (permalink) Old 12-14-2015, 09:54 AM
Intake Cam Actuator connector - 13587320 $40.68
Exhaust Cam Actuator connector - 19178093 $29.59
Both of these are connector kits(?) available through GMPD
DesertSol is offline
post #191 of 192 (permalink) Old 03-01-2016, 05:02 PM
Need the part number for 2007 GXP Clutch safety switch?
Sarge7 is offline
post #192 of 192 (permalink) Old 03-02-2016, 05:32 AM
GM Parts Direct: Your direct source for Genuine GM Parts
Here's your link, very bottom of the page. According to what you are looking for, I think it's 22620888 CLUTCH SWITCH
SWITCHES for 2007 Pontiac Solstice
  LinkBacks (?)
LinkBack to this Thread: https://www.solsticeforum.com/forum/f12/solstice-gm-part-numbers-22079/
Posted By For Type Date
GM OEM Rear Facia for Sol - Saturn Sky Forum This thread Refback 04-25-2008 06:22 PM
