solsticeforum needs your help (tech issues collection) - Pontiac Solstice Forum
post #1 of 5 (permalink) Old 08-21-2006, 09:03 PM Thread Starter
Administrator
SolsticeMan's Avatar
Many people are on the site, and a distributed task is much easier than a single person attempting to do it.
the subject is "Technical Issues" with solstice/kappa.
We'll be looking to consolidate these into two main threads (or one main reference thread) with links to the discussions. this should help multiple discussion threads and make getting to what we all collectively know about the car easier for noobs and veteran members alike.
So, here's how you can help:
Pick an issue (like "differential clunk"), find all of the links that discuss it (there are about a dozen that come to mind), and post them in a subsequent post, with a listing of the subject ("differential clunk") and whether there is a solution for this issue or not (no immediate solution? Possible solution?)
Or "foam blocks in trunk". Or "water leaks".
Don't forget issues that have been addressed or solved, even if all it took was you going back to your dealer.
Eventually, we can consolidate these into a reference thread to find technical issues and whether they have a solution or not.
SolsticeMan is offline
post #2 of 5 (permalink) Old 08-21-2006, 09:26 PM
CCrew's Avatar
Is "deleted links" a subject? LOL
CCrew is offline
post #3 of 5 (permalink) Old 08-21-2006, 10:20 PM
Small Dealer's Avatar
Don't know what you have in mind, but here is the 2006 Solstice Service Manual section titles (with two title for the 2007 2.0L Turbo).
If you were going to list the new compilation threads, perhaps this order/grouping would work. Or maybe it is too much. Just a thought.
Bulletins
General Information
-General Information
-Maintenance and Lubrication
-Vibration Diagnosis and Correction
-Air/Wind Noise
-Squeaks and Rattles
-Waterleaks
HVAC
-Heating, Ventilation and Air Conditioning
-HVAC Systems-Manual
Steering
-Power Steering System
-Steering Wheel and Column
Suspension
-Suspension General Diagnosis
-Wheel Alignment
-Front Suspension
-Rear Suspension
-Tires and Wheels
Driveline/Axle
-Propeller Sahft
-Wheel Drive Shafts
-Rear Drive Axle
-Drive Axle-Locking/Limited Slip
Brakes
-Hydraulic Brakes
-Disc Brakes
-Park Brakes
-Antilock Brake System
Engine
-Engine Mechanical-2.4L
-Engine Mechanical-2.0L
-Engine Cooling
-Engine Electrical
-Engine Controls and Fuel-2.4L
-Engine Controls and Fuel-2.0L
-Engine Exhaust
Transmission
-Manual Transmission-Aisian AR5
-Shift Lock Control
-Automatic Transmission
-Clutch
Body
-Body Front End
-Body Rear End
-Bumpers
-Collision Repair
-Doors
-Exterior Trim
-Frame and Underbody
-Horns
-Instrument Panel, Gages, and Console
-Interior Trim
-Lighting Systems
-Paint/Coatings
-Plastic Panel Information and Repair
-Roof
-Seats
-Stationary Windows
-Wipers/Washer Systems
-Wiring Systems
Restraints
-Seat Belts
-SIR
Vehicle Control Systems
-Vehicle DTC Information
-Computer/Integrating Systems
-Programming and Setup
Accessories
-Cellular Communications-OnStar
-Cruise Control
-Entertainment
-Keyless Entry
-Personalization
-Power Outlets
-Theft Deterrent
INFORMATION POSTED ON SITE
Small Dealer is offline
post #4 of 5 (permalink) Old 08-22-2006, 07:08 AM
If the issues were to be rewritten into a new post or thread, they could follow the recommended format of a repair order: Concern, Cause, Correction.
post #5 of 5 (permalink) Old 08-22-2006, 07:17 AM Thread Starter
Administrator
Great idear!
