Suspicious sounds from the GXP engine? - Pontiac Solstice Forum
 6Likes
  • 1 Post By TomatoSoup
  • 1 Post By TireKicker
  • 1 Post By The_Ghost
  • 1 Post By znaut
  • 1 Post By Greatgab
  • 1 Post By raygun
post #1 of 8 (permalink) Old 03-09-2019, 10:06 AM Thread Starter
patrikspacek's Avatar
Hi Guys,
can somebody identify this "possible" issue I hear from my engine?
The video includes 2 different sounds coming off the engine. Can you tell me, if its a problem I need to fix?? or what is it? I dont like it, it sounds like old diesel
sound #1 more like diesel rattle
sound #2 clock ticking
VIDEO here:
https://drive.google.com/open?id=1eG...LEv4rb1VBX5AJU
thanks
Patrik Spacek
Founder of Went2Play
Video Games Developer
patrikspacek is offline
post #2 of 8 (permalink) Old 03-09-2019, 10:21 AM
Not sure what the first one is, other than normal.
Second one is the HPFP. Definitely normal.
patrikspacek likes this.
post #3 of 8 (permalink) Old 03-09-2019, 12:27 PM
TireKicker's Avatar
I think its just the way they sounds close the hood.
TireKicker is offline
post #4 of 8 (permalink) Old 03-09-2019, 02:47 PM
Both are your High Pressure Fuel Pump(HPFP)...normal sounds. Vid1 is your HPFP when your motor is cold and it sounds like a diesel. Vid 2 is normal once all sensors reach operating temp...clock tick. Both are you HPFP at different cycles.
post #5 of 8 (permalink) Old 03-09-2019, 03:18 PM
znaut's Avatar
Sounds just like my GXP
znaut is online now
post #6 of 8 (permalink) Old 03-09-2019, 06:00 PM
Greatgab's Avatar
The sounds of LNF magic... drive that bad boy!
2008 GXP Aggressive Red - SOL LVR - Trifecta custom tune - DDM CAI/charge tubes/silicone hoses - Werks IC - Solo Hi-flow Cat/Mach Shorty exhaust - DDM Probeam/Backbone/Venom brace - Short throw shifter - Full LED conversion - Michelin Pilot Sport 4S
Greatgab is offline
post #7 of 8 (permalink) Old 03-10-2019, 01:12 PM
Sounds normal to me.
Do you have the noise blanket under the engine cover? (There's also a small one over the HPFP.)
Someone should make an active noise cancellation device for the pump.
raygun is online now
post #8 of 8 (permalink) Old 03-14-2019, 06:32 AM Thread Starter
Thanks a lot guys! This baby has 105K and still kicks like crazy...
Patrik Spacek
Similar Threads
Sol GXP Coupe Before/After Solo Mach Sounds Vid ChopTop Solstice Coupe Discussion 1 02-08-2017 09:14 AM
GXP tune sounds good? Bluesulfur Solstice GXP Discussion 15 01-18-2011 06:26 PM
Engine sounds weird BlckSunShine General Tech, Solstice GXP Specific 3 12-04-2008 11:37 AM
Update on engine chatter... now sounds like ticking. CenturionAVRE General Tech, Platform Common Issues & Solutions 2 11-11-2006 03:36 PM
SOUNDs in the solstice minimac Mods - Audio & Etc. 34 01-03-2006 10:07 AM
