top acess door will not open when finally opened will not stay up - Pontiac Solstice Forum
post #1 of 6 (permalink) Old 10-08-2018, 08:56 AM Thread Starter
having trouble deck lid opening . will not stay open appears spring on pass side broken are parts available how do you you replace?
sly2 is offline
post #2 of 6 (permalink) Old 10-08-2018, 09:05 AM
sirwm's Avatar
search for "deck lid springs" is the custom search bar at the top of the page ( next to 'advertise' ).
You will see many threads on the topic.
also this one is interesting -> https://www.solsticeforum.com/forum/...unk-mod-57477/
Sir William's Fleet
sirwm is offline
post #3 of 6 (permalink) Old 10-08-2018, 10:15 AM
AKA SolWhat?
DaveOC's Avatar
@rob the elder
I assume you are referring to the torsion bar being broken. I'm pretty sure those parts are still available through a dealer parts department. Rob the Elder has a pretty good description of how to replace these, somewhere, if you can find it. In order to replace a torsion bar, you need to remove both the rear fascia and the rear bumper cover. It is a PITA job, in my opinion, best left to a dealer to do.
YMMV
1st 1K - #741
DaveOC is offline
post #4 of 6 (permalink) Old 10-08-2018, 11:21 AM Thread Starter
thanks for the info. I determined the torsion bar on one side is broken. will try to find one and replace thanks. will try the spring idea also
sly2 is offline
post #5 of 6 (permalink) Old 10-08-2018, 12:26 PM
ChopTop's Avatar
Forum member Riggs314 would also be someone else to reach out too since he's removed his decklid several times to install his Edag hardtop. Let us know how it works out for you.
ChopTop is offline
post #6 of 6 (permalink) Old 10-08-2018, 05:35 PM
replacing the torsion bar is tedious but not hard. You need to remove the rear bumper cover, then you will have direct access to the torsion bars.
https://www.solsticeforum.com/forum/...ml#post1106621
rob the elder is online now
