trunklid - Pontiac Solstice Forum
 3Likes
  • 3 Post By JenHow
post #1 of 6 (permalink) Old 12-22-2018, 01:28 PM Thread Starter
trunklid
2006 solstice trunklid opens intermittently. Once the trunklid is open when I use my remote/ fob it does not release the wings that are attached to the convertible top which are supposed to pop up when pressing the trunklid button on the remote/fob. I have put new batteries in the remote/fob without any improvement. We are experiencing winter weather conditions here in California and the car is parked outside all the time and has never been garaged. Please advise?
bes-art is offline
post #2 of 6 (permalink) Old 12-22-2018, 09:05 PM
Welcome to the forum
Sounds like the buttresses are not releasing. You can do it manually using a small tool to force the latch open then look at the solinoid that activates the cable
Check your fuses as well. You might have one gone bad
post #3 of 6 (permalink) Old 12-23-2018, 02:50 PM
joybill44's Avatar
Like Rob says, you can release the buttresses manually. Use a very small screwdriver or a something like a 2mm allen wrench. Stick it vertically in the hole right behind the buttress pin (toward the rear of the car) and force it forward beside the pin on the inner side ( toward the center of the car). The pin will pop right up.
A little cursing may help also, it can be a tricky maneuver the first time you try it.
Bill.
joybill44 is offline
post #4 of 6 (permalink) Old 12-24-2018, 12:43 PM
JenHow's Avatar
I had the same problem the plastic grommet that holds the cable broke I found that using the round part of a hanger will fit down inside and pop it to open it once I did that I found an eyehole screw used it to replace gromet, look at the picture it works fine.
JenHow is offline
post #5 of 6 (permalink) Old 12-25-2018, 05:28 AM
sirwm's Avatar
me too - same issue.
here is my story -> https://www.solsticeforum.com/forum/...n-trunk-79201/
Unfortunately, all of the good pictures that I did are gone.
However, there are still two useful pictures in the thread that might help...
Sir William's Fleet
sirwm is offline
post #6 of 6 (permalink) Old 12-27-2018, 05:24 PM Thread Starter
Are you talking about the grommet that sits between the oval hole on deckled that is chrome and the buttress lock pin plate that is plastic and is held by two self tapping screws? I am looking for 2 new grommets, one on each side of the decklid where the pins come down into the wire catch that holds the pin locked in place? I am trying to find the grommets because they are cracked from exposure from the elements. If you were able to find new ones, please share that info with me so I can replace my grommets? Thanks in advance.
bes-art is offline
