Pontiac Solstice License Plate LEDs! Plug & Play Install! Same day Shipping! - Pontiac Solstice Forum
 1Likes
post #1 of 16 (permalink) Old 11-19-2014, 11:15 AM Thread Starter
Diode Dynamics's Avatar
License plate bulbs are used to illuminate the rear license plate on your Solstice. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to Diode Dynamics' LED replacements, you can easily add this luxury look to your Pontiac Solstice!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Solstice looks at night.
Diode Dynamics offers several bulb options so you can choose what fits your needs best. These options are listed by the design and the lumen output of each bulb:
Brightness:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design:
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Pontiac Solstice).
Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Diode Dynamics: 2006-2009 Solstice License Plate LEDs
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 16 (permalink) Old 11-19-2014, 01:47 PM
Hmmm LEDs that have not yet found their way onto Punisher. Very interesting.
Windrestrictor! likes this.
post #3 of 16 (permalink) Old 11-19-2014, 01:50 PM Thread Starter
The HP3's are our newest 194-sized bulb
A simple upgrade, but a big result!
Nick C.
post #4 of 16 (permalink) Old 11-19-2014, 02:30 PM
GrandpaSolstice's Avatar
These guys know their stuff, Rob.
GrandpaSolstice is offline
post #5 of 16 (permalink) Old 11-19-2014, 02:36 PM Thread Starter
Thanks!
Nick C.
post #6 of 16 (permalink) Old 11-20-2014, 10:34 PM
GODROD's Avatar
Yeah Rob. Met Nick at a local car meet. Real deal.
SoloDio
2008 Brazen Orange GXP
GODROD is offline
post #7 of 16 (permalink) Old 11-21-2014, 04:52 PM
Robotech's Avatar
These are pretty cool. I see you have HID kits for the Solstice...I'm pretty sure the Sky lights are different enough that they won't work with our Sky's. Wish that wasn't the case.
07 Saturn Sky 2.4
Midnight Blue
MagnaFlow dual outlet exhaust
GMPP CAI
Info above for both my Skys. One owned from 06-07, one from 14 to present
Robotech is offline
post #8 of 16 (permalink) Old 11-24-2014, 07:54 AM Thread Starter
We have products available to replace nearly every standard bulb offered today, especially for domestic vehicles
If you send an email to: [email protected] or call: (314) 205-3033
We can definitely help you with replacement lighting for your Sky
I imagine the Solstice and Sky share pretty much all of the same lighting. The license plate lights are probably the same as most vehicles use a 194 bulb (few small exceptions)
Nick C.
post #9 of 16 (permalink) Old 01-09-2015, 12:21 PM
RedOne07's Avatar
I know that when tweaking / dressing up / tuning your car the most important thing is that the owner likes it and one should never ask "why". if it makes him happy that is good enough reason.
Well, I will still ask the question.. . . why . . . . . would you want your license plate to be better visible ?
RedOne07 is offline
post #10 of 16 (permalink) Old 01-09-2015, 12:34 PM Thread Starter
The factory license plate lights are a dull, boring incandescent yellow. Replacing them with cool white LEDs provides a much cleaner and modern appearance.
We offer a variety of bulb models with different levels of output, so you can pick the level of output you prefer.
If you aren't doing anything illegal in your car, you won't have to worry about your license plate's visibility anyway lol.
Nick C.
post #11 of 16 (permalink) Old 04-09-2015, 08:12 PM
FieroVin's Avatar
I see you have the information here in this particular post, but I think it would also be helpful if your website listed how many lumens the OEM style incandescent bulbs are so you can easily compare your LED light output to what you have now in the stock bulb. I didn't see it anyway, maybe I missed it. Just a suggestion. Thanks for supporting our cars.
Vin
http://www.facebook.com/Triangle2Seaters
https://www.facebook.com/groups/Triangle2Seaters
2008 Solstice GXP, Aggressive
1987 Fiero GT, Medium Red Metallic
2014 Dodge Durango R/T, Red Pearlcoat
1988 - 2006 - The 18 year dry spell between 2-seat Pontiac Excitement was finally over... RIP Pontiac 1926 - 2010
FieroVin is offline
post #12 of 16 (permalink) Old 04-10-2015, 07:54 AM Thread Starter
We are in the process of a major update to our site. Our development team has been working hard to compile detailed technical specifications for every bulb model we offer, and we will be adding more stock lumen output measurements.
It's difficult to provide real-world information for incandescent bulbs, because they will gradually lose output over time as the filament is worn away.
Osram-Sylvania was recently hit with a $30 million lawsuit for misleading customers by saying their products were x% brighter than the factory bulbs without explaining that the factory bulbs must be used over a significant period of time.
Anywho (lol), we are planning on having a Solstice in our studio at some point in the near future for product comparison shots and development.
In the meantime, feel free to contact us if you have any questions about fitment or lighting in general
Thanks!
Nick C.
post #13 of 16 (permalink) Old 05-30-2016, 03:55 PM
NYC_Sol's Avatar
Ha! I was thinking the same thing... I'd rather my license plate be harder to read, personally (no offense to DD as it looks like a very nice product)
2007 SLY w/ Ebony Leather & Top
Power | Convenience | Polished w/ Polished Caps | LSD | ABS | A/C | 6-Disc w/ MP3 | Monsoon | XM
GMPP CAI | GMPP Cat-Back Performance Exhaust | Kappashield | 2.55" Stubby | Kappapouch | GXP Alum Sill Plates | GM All Weather Mats & Splash Guards
My mother said to me, "If you are a soldier, you will become a general. If you are a monk, you will become the Pope." Instead, I was a painter, and became Picasso. ~Pablo Picasso
NYC_Sol is offline
post #14 of 16 (permalink) Old 05-31-2016, 08:00 AM Thread Starter
We have a variety of bulb models depending on how much light output you are looking for.
Having a visible plate gives LEO one less reason to pull you over FWIW
Nick C.
post #15 of 16 (permalink) Old 01-05-2018, 09:39 AM Thread Starter
Thanks !
Thank you!
Nick C.
