Pontiac Solstice Turn Signal LEDs! Plug & Play Install! Increased Output! - Pontiac Solstice Forum
 1Likes
post #1 of 15 (permalink) Old 10-16-2015, 07:14 AM Thread Starter
Diode Dynamics's Avatar
From the factory, turn signal bulbs are powered by standard incandescent lights that light up amber in color.
Newer luxury vehicles are using LEDs for turn signals, because LEDs offer a crisp, instant on/off, increased brightness, and true, vibrant color. By replacing the bulbs in your Solstice, you can achieve this modern look!
Resistor Option: The Pontiac Solstice will hyperflash when LED bulbs are installed as turn signal replacements. Diode Dynamics' offers a resistor kit option to remedy this issue
Diode Dynamics carries the brightest, highest-quality bulbs available. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits your needs best. These options are listed by the design and the lumen output of each bulb:
Brightness:
HP48: (280 lumens) Similar brightness to OEM bulbs
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
Diode Dynamics: Front Turn Signal LEDs for 2006-2009 Pontiac Solstice
Diode Dynamics: Rear Turn Signal LEDs for 2006-2009 Pontiac Solstice
Diode Dynamics: Tail Light LEDs for 2006-2009 Pontiac Solstice
Any questions, feel free to ask via email ([email protected]), Post or shoot us a PM!
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Diode Dynamics
How to Install Resistors for LED Turn Signals & Fix Hyper-blinking
Diode Dynamics is offline
post #2 of 15 (permalink) Old 10-16-2015, 04:42 PM
WintR's Avatar
The front turn signals use a 3757A bulb, which require cutting the tabs off the edges of the 3157 style base. Are there any plans to make a base that fits the 3757 style? I seem to recall the 3757 will fit the 3157 socket without modification, but haven't tried it.
Also, are there installation instructions for the resistor kit?
Mods: Kappasphere CAI, Clear Image Shorty Header, second horn, visor decals, mudflaps, tonneau cover, brake light flasher, trailer hitch, 'lil Chromies, trunk monkey, retune, DDMWorks backbone, GMPP Suspension, wood grain dash, Solo Quiet cat-back exhaust, deleted:Solo high-flow cat
WintR is offline
post #3 of 15 (permalink) Old 10-19-2015, 07:01 AM Thread Starter
3757 is a cross reference number for 3157, so they will be a direct replacement for the Solstice.
Here's a video demonstration of how the resistors are installed:
Thank you,
Nick C.
post #4 of 15 (permalink) Old 10-19-2015, 08:33 AM
WintR's Avatar
As I understand it, the 3157 has small tabs on the edges of the base, which prevent insertion into a 3757 socket, as the 3757 does not have these tabs. The photo shown above shows these tabs, which means they will not fit into a socket for the 3757. A 3757 should, however, fit into a 3157 socket, which is why it shows up as a replacement for a 3157. I recall having to cut the tabs from a 3157 bulb to replace my bulbs.
WintR is offline
post #5 of 15 (permalink) Old 10-19-2015, 08:37 AM Thread Starter
Sockets differ from manufacturer to manufacturer, but the standard bulb sizes are:
1156/1157
3156/3157
7440/7443
We carry these three major sizes, which fit about 98% of the vehicles on the road today. The tabs on the sides can differ, but our options will fit with minimal modifications.
Nick C.
post #6 of 15 (permalink) Old 10-19-2015, 04:34 PM
WintR's Avatar
If you have one in stock in Earth City, I can drive over and we can test-fit, just to be sure. If it does fit, I'll go ahead and buy them.
WintR is offline
post #7 of 15 (permalink) Old 10-20-2015, 06:43 AM Thread Starter
We'd be happy to take a look! Come visit us at your earliest convenience
Nick C.
post #8 of 15 (permalink) Old 02-20-2016, 05:35 PM
typhoon's Avatar
Ya know, there are a lot of LED bulbs out there that have the resistor built in to eliminate hyperflash. Why can't you guys do this???
GONE--2008 GXP 5 speed manual Brazen GMPP upgrade
2008 Cadillac SRX AWD N*
2016 GMC Sierra Denali 6.2
2012 Cadillac CTS4 3.6DI Wagon-Premium
2003 Honda ST1300
1965 Bolens tractor. w/new 13hp crate motor
2000 pair of roller blades
2008 Limer backpacking shoes
typhoon is offline
post #9 of 15 (permalink) Old 02-22-2016, 09:19 AM Thread Starter
There are a lot of LED bulbs out there that "claim" to have resistors built in and eliminate hyperflash, but it's not possible if you want to have a reliable LED product.
Heat is a byproduct of electrical resistance. Heat is also the biggest enemy to LEDs and will cause premature failure.
If you were to integrate enough resistance on the base of the LED or the LED itself, you'd definitely shorten the lifespan of the LED or it might fail after just a few turn signal cycles.
By adding resistors into the wiring, you are placing that heat away from the LED where it can't create any possibility of damaging the LEDs.
We are always improving our products as technology improves, but heat is still the biggest limiting factor for LED bulbs.
Nick C.
post #10 of 15 (permalink) Old 04-02-2016, 10:00 AM
I wish there was a way to install these without losing the ability to automatically detect a failed bulb.
post #11 of 15 (permalink) Old 04-28-2016, 03:04 AM
Can't there be an adapter made that could be placed between the bulb socket and the connector that could isolate the resistors from the bulbs, and thus eliminating the need to cut into the wiring?
Blue2007 is offline
post #12 of 15 (permalink) Old 04-28-2016, 07:47 AM Thread Starter
Our engineering team is in the process of developing new solutions for resistor harnesses, but I don't have an ETA available for their release.
Nick C.
post #13 of 15 (permalink) Old 04-28-2016, 08:43 AM
Here's a tip...
With our cars, the front and rear turn signals are on the same detecting circuit. That means you only need to install a load resistor at the front to handle LEDs in the front OR rear turns (if you have both w/LEDs you'll need a lower resistance resistor, or two in parallel).
You can then install these resistors in the front (short) pigtails between the connector in the front of the engine bay and the fog/turn lamp assembly. Those pigtails are available used from many other GM cars, or even new aftermarket if you ever want to go back to 'stock'. That all means that you don't need to damage the larger wiring harness in the car.
TomatoSoup is online now
post #14 of 15 (permalink) Old 02-15-2017, 12:29 PM Thread Starter
How to Install Resistors for LED Turn Signals & Fix Hyperblinking - Diode Dynamics
post #15 of 15 (permalink) Old 04-30-2018, 09:09 AM Thread Starter
Behind the LEDs: Trevor Dobbins
