Log in fine, sometimes cannot post, told to log in - Pontiac Solstice Forum
post #1 of 9 (permalink) Old 05-18-2019, 02:12 PM Thread Starter
Then when I try to log in again, I'm told I'm logged in and I'm being silly.
Whiskey Tango Foxtrot Over
Yes have tried "remember me". No impact on the issue
Gone but not forgotten:
ChrisBlair is offline
post #2 of 9 (permalink) Old 05-18-2019, 02:14 PM Thread Starter
I literally just tried to reply to an active topic. Told that I'm not logged in.
post #3 of 9 (permalink) Old 05-18-2019, 02:17 PM
RedOne07's Avatar
Often it helps when you clean up cache, delete cookies, restart system
RedOne07 is offline
post #4 of 9 (permalink) Old 05-18-2019, 02:34 PM Thread Starter
True but that shouldn't be necessary.
post #5 of 9 (permalink) Old 05-18-2019, 02:46 PM Thread Starter
Was there a deleted reply, or was I seeing a reply to another thread? Refresh issue maybe?
Everything I do is up to me, obviously, but I was able to start this thread, then I tried to reply to an active topic and was told I needed to log in, then when I did I was told I was already logged in.
My experience tells me that successfully logging in and starting a thread means I have performed my process correctly.
Subsequently and immediately being informed that I must log in again, then when I do so being told I am already logged in, does not seem to be a failure in my process, especially since now- without doing anything at all- I can reply to the thread I was unable to reply in originally.
If non-action on my part allows success- which has happened- then something outside of my side of things is logically going on.
post #6 of 9 (permalink) Old 05-18-2019, 05:18 PM
So this was my issue. Here's the steps I did:
click the remember me box
login
close all windows of the browser you're using
open browser up
go back to solstice forum
at this point you should be logged in now...
****Trust me, clearing your cache isn't going to solve the issue!!!**** It's an obvious problem with the webpage itself and certain settings within the browser. What those settings are??? I have no clue.
post #7 of 9 (permalink) Old 05-19-2019, 04:44 AM
Location: Phoenix Arizona where there are about 250 days a year for convertible Bebop-ing
OK Chris, I had the same. The only way it works for me is if I log in First Thing when I open the main page. For instance I tried to answer and had to go back and start from scratch in order to reply. Good luck!
Bebop2 is offline
post #8 of 9 (permalink) Old 05-19-2019, 05:44 AM Thread Starter
CMP forums was doing a similar thing last year. Frustrating. I wonder if I can post this.
post #9 of 9 (permalink) Old 05-19-2019, 05:45 AM Thread Starter
Huh. I can.
Thanks guys!
Similar Threads
Dashhawk log comparisons, post your's shabby General Tech, Solstice GXP Specific 0 05-19-2007 03:51 PM
Sometimes its good to reflect the start of it all [Origins of Solstice Concept] MGA1500 Solstice and other Automotive Related News 11 08-28-2005 01:41 PM
Sometimes it Just Sucks Being Canadian Danno General Solstice Discussion 26 07-23-2005 03:39 PM
Cannot post in Sky section... Fformula88 General Off Topic 14 02-01-2005 07:01 PM
