P0455 and Radiator hose ? - Page 2 - Pontiac Solstice Forum
post #16 of 19 (permalink) Old 09-10-2019, 05:11 PM Thread Starter
Vincent1313's Avatar
Originally Posted by Vincent1313 View Post
What I see on that screenshot is a list of things that could cause this fault, not any indication of something that was actually fixed.
The solenoid, canister, or filler pipe could all be at fault if a connection was not made correctly or has come loose.
The test for this problem only runs when the engine is started cold, and will not run if the fuel tank is completely full. In only 100 miles you may have only run the test once, so the original problem may not have been fixed. I think you should find out how they verified that they fixed it the first time.
Ok tyvm I am taking it in tomorrow. So will explain what is happening and what was done so maybe they can figure it out easier. If not will let them run there test and tell me for sure what it is and how much it will be to fix. I thank you Jonh for all your help and fast answers.
There was a P0466 code they fixed as the solenoid problem. So maybe they thought they fixed cause cleared that code.
Vincent1313 is offline
post #17 of 19 (permalink) Old 09-11-2019, 02:26 PM Thread Starter
They did smoke test today and said found nothing. So asked them to check purge valve do to they found nothing else. So I told them to just leave it as then. They can't figure out problem without costing me a butt load. I don't get good gas millage as is so guees it will stay that way.
post #18 of 19 (permalink) Old 09-11-2019, 04:32 PM Thread Starter
Can I get to the purge canister through the trunk? Seen tread talking about this would not let me add or post on it. These are pics guy sent about it. But I don't think my trunk looks like that. Is it possible to cut into plastic in trunk in pictures and fix also what he wrote. Just thinking about replacing due to code in this post and there was no evap leak. So has to be purge level or contol valve or solenoid. Solenoid was repaced for P0466 think thats code. That code went away after he did now again have P0455 evap test done and was told no evap leak. He preformed smoke test and said there was no leaks. So what could it be since no leak in evap system and still have p0455. And yes replaced gas cap. Tyvm
ID:	99289   Click image for larger version
ID:	99291   Click image for larger version
post #19 of 19 (permalink) Old 09-13-2019, 11:15 AM Thread Starter
What can it be if passed smoke test?
